TireRack
Old 08-12-2013, 04:03 PM   #99
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Crank, rod and cam bearings.
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
litle88 is offline   Reply With Quote
Old 08-12-2013, 05:43 PM   #100
Chris@Livernois
Chris@Livernois's Avatar
Drives: 2010 Camaro
I heard someone say my name... How may I be of service on this wonderful Monday?
Chris@Livernois is offline   Reply With Quote
Old 08-12-2013, 06:20 PM   #101
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Lol!!! There you are!
Contact p.q. would ya lol
Old 08-13-2013, 08:27 AM   #102
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
You could put some forged boost ready pistons in there while it's apart. At your power level it would be pretty bullet proof unless you get the itch to go crazy adding boost.
Sent from my HTC One X using Tapatalk 4
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 08-13-2013, 11:21 AM   #103
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
If it were me PQ and your bores being ok. I'd either keep the crank and forge it (rods and pistons) and have ie Lethal, vengeance or proline build it or get the striker kit an sell your rotating assembly. Only if your block is good. Just my .2
Old 08-13-2013, 12:19 PM   #104
Chris@Livernois
Drives: 2010 Camaro
PQ did have you and Dave spoke again since last week about your options?
Old 08-13-2013, 12:46 PM   #105
I have to disassemble it to know though correct?
But wouldn't I have to have the cylinders honed anyway?
What is a striker kit?
He sent me the specs and costs. There are a few things I do not know what is but I have them and it's money saving mode now.
I assumed that SS was the street version?
Old 08-13-2013, 01:10 PM   #106
Livernois Motorsports
Livernois Motorsports's Avatar
Drives: 2010 Camaro 454 LSX (SOLD)
You should have the cylinders honed no matter what to make sure the piston fitting is to spec.
I believe he meant a "stroker kit" just mispelled it!
Yes the SS is our "Street Series"
Any other questions sir?
Livernois Motorsports is offline   Reply With Quote
Old 08-13-2013, 01:33 PM   #107
Cool.
I totally should have caught that. lol
Lot's. But need to get my rotating assembly apart first.
Pics to come.
Old 08-13-2013, 02:24 PM   #108
Jayrcr3
Jayrcr3's Avatar
You will have to disassemble it to put new bearings in.
Don't confuse honing and boring. Boring is when you enlarge the cylinder bore for bigger pistons. Honing is when you slightly rough up the cylinder walls with a cross hatch pattern. You likely don't need to bore the cylinders unless they are out of round, or are screwed up in some way.
Pretty sure he meant stroker kit.
Old 08-13-2013, 03:56 PM   #109
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
Proline builds good motors! That's who built mine! But you have to go through vengeance to get it done! I do believe!!!
csjcsj is offline   Reply With Quote
Old 08-13-2013, 04:18 PM   #110
Chris@Livernois
Drives: 2010 Camaro
Jayrcr3 is exactly right, two completely different things. If the walls aren't scored or scratched you should still hone the block to make sure its cleaned up properly. If you go to a larger piston it will need to be bored and honed.
When you get the rotating assembly apart send me pics of everything so we can look it all over.
Old 08-13-2013, 04:27 PM   #111
1Camaro2SS
1Camaro2SS's Avatar
Drives: 2010 2SS/RS L99
Hey aren't you the guy who did a cam swap and lost oil pressure? Did you end up rebuilding that same motor?
432 RWHP 391 RWTQ 12.37 1/4 mile on stock tires
1Camaro2SS is offline   Reply With Quote
Old 08-13-2013, 05:39 PM   #112
Got it.
Vengeance did the cam and tune.
Livernois are my guys at this point whatever I decide. I might just disassemble it and order the stroker kit. The stock crank is good for I think 900 HP iirc. Forged stroker kit and a new valv train with worked heads might be the ticket. I've heard tale that the Maggie with a 419 might be too slow. I'll list my options soon.
I have 3 options at this point. Maybe 4.
