Roto-Fab
Old 04-02-2013, 08:05 AM   #1
Rjgreen2
Rjgreen2's Avatar
Drives: 2016 Chevy Camaro SS
More Cam questions
Mostly a noob here but I am looking into learning more about cams and how to know what I am choosing. I have a 12 Camaro SS LS3 that is a my DD with a CAI and a Corsa exhaust with plans in another week or two to go with the Kooks stepped headers. I have been searching around the internet and mainly around Camaro5 and have read so many different threads on cams. I am still trying to learn everything I can about how to "pick" a cam and what the different xxx/xxx duration and xxx/xxx lift means in regards to choosing one that will fit my application. I have heard the terms low-mid range and mid-high range thrown around a bit. At what point does it become a drive ability issue? Also, I am assuming that choosing a cam will change the exhaust note around right? In talking with one of my buddies on here, I believe I came up with maybe something mid-high with a deep exhaust note???
Oh yea, and one more thing, after I get the cam figured out and installed, the day WILL come that I put on a SLP TVS2300, but only in time. Any help or pointing me in the right direction would be greatly appreciated.
Ryan Green
2016 Chevy Camaro SS Hyper Blue Metallic
2012 Chevy Camaro SS 45th Anniversary - SOLD (still kicking myself for doing that)
Order Status
2000 - 1/4/16
2500 - 1/6/16
3000 - 1/7/16 - TPW 2/1/16!!!
3400 - 1/18/16
3800 - 1/30/16 - VIN# 145458
4300 - 2/2/16
4B00 - 2/4/16
4300 - 2/13/16 - Moving somewhere
4200 - 2/16/16 - SHIPPED!!!!!
5000 - 2/18/16
6000 - 2/19/16 - Its MINE!!
Rjgreen2 is offline   Reply With Quote
Old 04-02-2013, 08:12 AM   #2
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
Your best bey is to talk with a couple of vendors like jannettt lethal fsp texas speed you might also try compcams lunati to name a few if youre doing a supercharger you might want a blower cam
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 04-02-2013, 08:19 AM   #3
Rjgreen2
Rjgreen2's Avatar
yea, will have to drop them a line. The supercharger probably wont happen till late in the year or maybe early next year.
Ryan Green
Order Status
2000 - 1/4/16
2500 - 1/6/16
3400 - 1/18/16
4300 - 2/2/16
4B00 - 2/4/16
5000 - 2/18/16
Old 04-02-2013, 08:27 AM   #4
BLACK10
BLACK10's Avatar
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60'
feel free to give us a call here at Lethal Racing. We would be happy to answer any questions that you may have regarding cam choice that will work best for you.
Thanks,
Nick
BLACK10 is offline   Reply With Quote
Old 04-02-2013, 08:38 AM   #5
Kelly@PCMofNC
Drives: 2010 RS/SS
Your best bet is to call a few vendors, see who fits you best, and let them decide for you. We do this work day in and day out, and whether or not we stay in business depends on our results, so we are driven to build the best cars possible!
You're not very far from us at all, we have a lot of folks come down from your area. We've got a great cam, the '545' cam, that is perfect for naturally aspirated cars and also for forced induction down the road. That's the path that a LOT of folks take - they do the bolt ons, add a cam, maybe some heads, and then when they get bored with that they add a blower. It's convenient if the cam you have is a good match for the blower, that way you aren't holding back on power later or taking the time to swap it again.
Naturally aspirated, the '545' cam does about 470-480rwhp with bolt ons, and right at 500rwhp with heads. With a blower, really the sky is the limit. I have the '545' in my own car and laid down 698rwhp on 10 lbs of boost. The driveability is excellent, and it has that great lope to it also...which most of us are after!
Check out a few of our build blogs with this cam to get an idea -
LS3 w/ 545 cam
LS3 w/ 545 cam & heads
LS3 w/ 545 cam, heads, and TVS 2300
This gives you an idea of the sound:
Kelly@PCMofNC is offline   Reply With Quote
Old 04-02-2013, 09:53 AM   #6
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
You may want to contact Pat G. He can spec a custom cam designed for your Camaro and specific mods.
http://www.guerragroup.com/#!camshaft-help/c1mq5
LSX Camaro is offline   Reply With Quote
Old 04-02-2013, 11:12 AM   #7
POS Dakota
POS Dakota's Avatar
Drives: GMs and Chryslers
That 545 cam looks like it would be a nice driving cam.
POS Dakota is offline   Reply With Quote
Old 04-02-2013, 11:49 AM   #8
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
You can get cams specd and Tailored to your wants and current and future needs. I personally like the NF cam, and can also be used in FI apps. From what I've read and witnessed personally it drives good, makes good power. But if I wanted a custom cam I'd call Brian Tooley racing or Ed Curtis to spec me a cam.
You'll also need supporting mods and those are
- trunion upgrade
- Brian Tooley racing dual platinum springs that have a "0" failure rate.
- chromoly pushrods
- melling 10296 pump
- c5r timing chain, stay away from the dbl rollers, you'll need the timing cover ground down for clearance issues.
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
litle88 is offline   Reply With Quote
Old 04-02-2013, 12:03 PM   #9
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
- trunion upgrade
- chromoly pushrods
And have lots and lots of headaches with the dbl roller clearance issues lol
Nightmare2012 is offline   Reply With Quote
Old 04-02-2013, 12:20 PM   #10
Rjgreen2
Rjgreen2's Avatar
Yea litle, I have seen many of your posts in regards to the supporting mods, which I actually have written down here to go with the cam. Which has helped out a lot btw. My other question for you guys is, will I have to wait to put the new cam in to measure for push rods or just purchase whats recommended? Like I said its my only vehicle at the moment and if I do have to leave it torn apart to properly measure the rods I would need to borrow my buddy's ride or something while waiting for the new rods to go in.
Ryan Green
Order Status
2000 - 1/4/16
2500 - 1/6/16
3400 - 1/18/16
4300 - 2/2/16
4B00 - 2/4/16
5000 - 2/18/16
Old 04-02-2013, 12:26 PM   #11
Nightmare2012
come find out;)
It is recommended you wait because every engine is similar but not the same thankfully my pushrods actually fitted when I ordered mine prior to tearing apart but that's a chance I took because of lack of research. I am now more knowledgeable and I realize research is of extreme importance, and in order to do things right the first time it is an essential step! Good luck and happy modding: thumbsup:
Old 04-02-2013, 12:55 PM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
If you go with the NF (for example) they'll tell you what size they recommend AS LONG as you don't mill the heads and you won't need to measure.
Old 04-02-2013, 01:05 PM   #13
Joe@CPR.com
Drives: 03 vette, 94 trans am, 04 gto
We have so many different cams out there we would love to help you pick something that works best for you!
Joe@CPR.com is offline   Reply With Quote
Old 04-02-2013, 01:12 PM   #14
LeanPocket
Drives: 2010 2SS
- trunion upgrade
- chromoly pushrods
+1 on the brian tooley springs
This is the route I am going with, i suggest the same with your build OP.
LeanPocket is offline   Reply With Quote
