Old 11-29-2017, 08:26 PM   #1
Galonso$*
Galonso$*'s Avatar
Drives: 2012 Camaro SS/RS
Camaros with corvette Wheels
I’m sure a lot of you got corvette wheels on your rides. Can you guys post any pics of them? Thinking of getting either silver ZR1 set or gloss black Grand sport rims to run some MT ET S/s tires on the rear(both have a 40 mm offset). Also would the rims fit the front of the car?
2012 Camaro 2SS L99, LT KOOKs Headers with Highflow Cats, Straight Piped, BTR Stage 2 Cam w/ tune and DOD/AFM delete
Galonso$* is offline   Reply With Quote
Old 11-30-2017, 03:31 PM   #2
12blkgrayRS
12blkgrayRS's Avatar
Drives: 2012 Camaro RS 2LT 6spd man
Hmm...corvette rims are smaller than the current Camaro offerings which are 20x9's, 20x10's, 20x11's respectively depending on the model. LS's and non-RS 1LT models run an 18 base and 19 in alloys as well. All 1SS-2SS run a 20'in rim. I think the vettes are running a smaller rim size and a different offset than the Camaro (they do fit though), some vettes are running 18's/19's frt-back.. Most guys here are drooling on the ZL1's/1Le rims. But I would think that most vette rims (Z06 &ZR!) would make a good track wheel albeit they will not be cheap..
12blkgrayRS is offline   Reply With Quote
Old 11-30-2017, 03:36 PM   #3
Welker2
Ret AF, cancer survivor
Welker2's Avatar
Drives: 2013 Camaro 2SS/RS & 2006 Corvette
You are correct about the Corvette wheels, my 2006 C6 has 18/19 F/B, which is pretty much standard.
Welker2 is offline   Reply With Quote
Old 11-30-2017, 05:21 PM   #4
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
Plus I don't recall but I'm almost sure that the offsets will not work right with the brakes. I think someone else was on here asking about running smaller corvette wheels as drag wheels.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
corvette, replicas, rims, tires, wheels
