Roto-Fab
Old 09-02-2011, 04:22 PM   #1
Driveshaft bearing gone bad .......
Ok folks. I'm going to do something out of the ordinary and post up another broke piece of my car.
So my noise turned out to be the drive shaft holder bearing/carrier bearing/cradle bearing/hanger bearing whatever you want to call it. it's going out and the clunk noise is from the play in the driveshaft.
So I will send the assembly to have a new bearing pressed on.
The shop tells me that all my extra power has little to do with the bearing going out but the extreme drop on my car has the shaft too angled. He says the angle is meant for acceleration flex and not constant bend. He says I should shim the motor mounts to straighten the line up.
My question is this ........
Has anyone else had any problems in this area on a stock lineback?
I know I've seen it before, but this U Joint looks pretty stout and solid and I can see where it could put pressure on the hanger as it turns but I don't know if I want to angle the engine. It already lays back a bit anyway.
What are your thoughts.
I did find the other thread, but it's been another year since then and the cars have had more time to break.
Old 09-02-2011, 05:00 PM   #2
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Send a message via AIM to DietCoke
The diff/engine are stationary. You could sit the frame on the ground and the ds angle would not change. Find a shop with a clue
DietCoke is offline   Reply With Quote
Old 09-02-2011, 05:40 PM   #3
In fairness, he only had the car on a drive on lift. So he may not know that. You have to remember, good shops in this area are hard to find. It's easy to say 'Find a shop with a clue' than to actually know wether a shop has a clue or not.
Either way, something caused my bearing to fail. And that was the best theory I had heard so far. I'm not a chasis/frame/body expert but I know it's possible. Maybe not on this car, but on some.
Can you explain why it wouldn't change the angle on our cars? I'm not sure how the driveshaft is supposed to sit but it is certainly angled right now.
Old 09-02-2011, 05:48 PM   #4
garcmol
garcmol's Avatar
Drives: 10 1LT SIM; 91 B4C sleeper Z
The half shaft out of the diff will change angles. The diff will stay constant. It has bushings but that's only to compensate for the torque produced. That's the wonder of the half shaft. Think when you jack the car up and the control arms drop but the diff doesn't. Then you put it on jackstands and release the jack. The diff does not change it's position.
But I guess a lot too.....
Pedders Pace Car Package, Injen CAI, Flowmaster AT, AAC Lighting, ZL1 fascia/skirts, RKSport Ram Air hood, vented fenders, painted stripes (Gary's Customz), Honor and Valor badged (Thank you, John)
garcmol is offline   Reply With Quote
Old 09-02-2011, 05:53 PM   #5
Well, I know the cradle seperates from the rest. And the diff is on the cradle. So I am unsure about the whole thing. I understand that it's all bolted together. But I know that raising and lowering on some other cars and trucks can cause a driveshaft angle. But I'm guessing that this is what they mean by unibody?
Old 09-02-2011, 05:55 PM   #6
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
right or wrong, what you gonna do??..mine has been dropped 1 1/2 inch for 6500 miles , 25 track runs , some hard running and no problems, actually all my problems started when i beefed up my shaft to a 1 piece to have one seperate and another twist and crack..in 700 miles and 2 runs..working on number 3 and if this 1 fails, heads will roll..
mikepage0007 is offline   Reply With Quote
Old 09-02-2011, 05:55 PM   #7
Again, in fairness, I told the shop that I was going to do the work myself so he just lifted the car and we walked under it and looked at the driveshaft only. He didn't really look at much else. He adimtedly doesn't know a lot about the knew Camaro. He did know it was a similar set-up to the GTO. But wasn't all that familiar with that either.
It's a transmission shop that I went to.
Old 09-02-2011, 05:58 PM   #8
So you're saying you seemed better off with the two piece?
At any rate, I'm goint to remove the X pipe and heat sheild, take the bearing off and send it to be done. Then I'll put it back together and chalk it up to another weird problem with my car.
Old 09-02-2011, 05:58 PM   #9
garcmol
garcmol's Avatar
Well, if I remember correctly, unibody has your subframe like our cars do. You'll see driveshaft angle changes with your solid axle vehicles because the rear differential is in the axle housing. Half shafts rely on your control arm setups to work. The suspension travel is separate of the differential in our setup, where as a truck with a solid rear axle is constantly changing angles
Old 09-02-2011, 06:00 PM   #10
mikepage0007
Drives: 2010 camaro
unforunately i have the 9inch rear so my stock 2 piece is useless, but as aggravated as i am right now, i would def put it back in till it breaks,,,
Old 09-02-2011, 06:08 PM   #11
garcmol
garcmol's Avatar
You're right the diff is attached to the cradle, but the cradle bushings are supposed to be sucking up the slop and the differential bushings move very little. They mainly suck up the torque curve produced by the driveshaft.
Old 09-02-2011, 06:09 PM   #12
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
If its angled at all, your center support got bolted in upside down. Flip it and rebolt it, and watch the shaft straighten itself out.
Old 09-02-2011, 06:11 PM   #13
DietCoke
Slow Turtle
DietCoke's Avatar
Drives: 2011 1SS
Cars with straight axles, have the entire axle assy move up/down with suspension height of car (diff free floating in axle). With irs (diff bolted to chassis) this isn't the case. Your centerpiece is prob upside down, like I said earlier. Thats the only way to angle the driveshaft
Old 09-02-2011, 06:15 PM   #14
bob vogel
Drives: 2010 rs ss
did your car make this noise all the time or just when it goes to a lower gear?
bob vogel is offline   Reply With Quote
TR6060 hydraulic bearing kit Fits 10-up Camaro Xplosive Performance Transmission / Driveline 5 05-21-2012 10:59 PM
FS. Brand New Camaro SS Two Piece Driveshaft with Center Bearing 55Designs Transmission / Driveline 4 12-08-2010 06:33 PM
Ball Bearing Blkcamaro757 Forced Induction - V8 9 07-29-2010 03:08 PM
2010 Camaro BMR Driveshaft Safety Loop pics!!! BMR Sales Dragstrip and Launch Techniques Discussion 29 12-12-2009 11:45 PM
2010 Camaro BMR Driveshaft Safety Loop Pics!!! BMR Sales Wheels and Tires Talk Sponsored by The Tire Rack 3 10-20-2009 11:21 PM
