07-11-2022, 04:25 PM | #1 |
Drives: 18 camaro zl1 Join Date: Dec 2020
Battery recharge system
So I was driving on the interstate just cruising and the message ‘service battery recharge system’ popped up and then a few minutes later went away. Then came back. Then went away. And it continued to do that all the way home. Car didn’t feel weird or anything and started back up with no problem. Any ideas what it could be?
07-11-2022, 05:59 PM | #2 |
disconnect, inspect, possibly clean, and reconnect the connector on the alternator that goes to the ECM. Check to see if it loose before you go and just pull it off, you might make an observation.
07-12-2022, 11:55 AM | #3 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
I'd have a load test done on the battery too.
07-12-2022, 01:41 PM | #4 |
What was voltage gauge doing when this happened?
This sounds like an intermittent connection problem in the main charging circuit. Battery terminals, alternator, and there is a main fuse somewhere. Did anything get wet anywhere? Last edited by ctrlz; 07-12-2022 at 02:08 PM. |
07-14-2022, 01:29 PM | #5 | |
And I’m not sure if the voltage because on the ZL1 that’s the boost gauge right? Unless there’s a gauge hidden in the display somewhere |
07-16-2022, 04:13 PM | #6 |
So if I have an underdriven pulley, wouldn’t this cause my alternator not to charge the battery enough ?
alternator, battery |
