Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 08-02-2022, 07:27 AM   #1
paradigm
Drives: 2022 Camaro 1SS 1LE
Which oil filter - 2022 1LE
I am reading older threads here with various suggestions on oil filters.
Which good performing oil filter should I be going with so that I am not denied a warranty claim on my 2022 1LE.
AC Delco PF64?
Wix 10290?
2022 Camaro 1SS 1LE 6-speed
paradigm is offline   Reply With Quote
Old 08-02-2022, 07:36 AM   #2
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
If warranty is a concern, stick with the ACDelco PF64, whichever the current part number/revision is.
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 08-02-2022, 07:38 AM   #3
Nothing like an SS
Faster!!!
Nothing like an SS's Avatar
Drives: 2020 Camaro 1SS 1LE
This ^^^^^^
Nothing like an SS is offline   Reply With Quote
Old 10-11-2022, 10:42 AM   #4
Dave88LX
Dave88LX's Avatar
Drives: 2022 2SS 1LE 6 MT
Anything wrong with the Delco PF64 that makes you want to change it?
2022 Camaro 2SS 1LE
Rapid Blue || 6MT
Dave88LX is offline   Reply With Quote
Old 10-04-2023, 02:45 PM   #5
paradigm
I was asking as I figured there may be a better than OEM filter.
But because of the warranty I am sticking to the OEM filter.
As a side note, I ordered a PF64 from Amazon yesterday and it has international packaging. When I saw the chinese writing I got worried.
Old 10-04-2023, 02:55 PM   #6
Iconic
Miller Time Wisconsin
Iconic's Avatar
Drives: '24 VOM 1SS 1LE M6. 1 of 4
Location: Formerly USA, now planet of the apes bizaroworld
I'm using Wix 10290 and no I didn't void my warrantee.
2024 1SS 1LE M6 rockcrusher in Vivid Orange Metallica. 1 of 4
Iconic is offline   Reply With Quote
Old 10-04-2023, 09:10 PM   #7
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Wix 10290xp made in USA. O'Reilly's.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is offline   Reply With Quote
Old 10-05-2023, 02:20 AM   #8
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
I have the same packaging, and I got mine from the dealership. I have seen comparison videos of knock off filters and spark plugs, so just be careful ordering from Amazon
CalgaryZL1 is offline   Reply With Quote
Old 10-05-2023, 05:52 AM   #9
dfwcowboy
dfwcowboy's Avatar
Drives: 2024 ZL1 M6, 1969 Cessna Skylane
There was considerable discussion here about which filter to use and it was noted the newer PF64 has a bypass setting which is specified by GM engineers for the engines used in the Camaro(22psi). Most other filters often have lower bypass levels or don’t specify their bypass rating. The idea is starts in cold weather conditions might cause the filter to bypass allowing unfiltered oil to circulate. Some people offered the rumor that using anything other than the spec’d filter will/might void your warranty. I don’t believe this is true and I know of nothing published by GM confirming this, although there was a TSB which details the concerns.
https://static.nhtsa.gov/odi/tsbs/20...37653-9999.pdf
dfwcowboy is offline   Reply With Quote
Old 10-05-2023, 06:52 AM   #10
JKOR
Drives: 2023 1SS 6 speed
I tend to go between Amsoil, Purolator, and K&N
JKOR is offline   Reply With Quote
