AWE Tuning
Old 02-26-2016, 01:11 AM   #1
Ant_ss
Drives: 14 1SS RS Black (rental)
LGX Engine ticking normal?
1lt rs with tech pack and a8 mbm
700 miles and she's had a ticking sound under the hood since I got her at 12 miles. No check emgine lights, funny smells, signs of leaks. Debating taking her to the dealer this Sunday :/
Any LGX owners experiencing the ticking while the engine is running?
Ant_ss is offline   Reply With Quote
Old 02-26-2016, 02:53 AM   #2
Gen_Nick3.8
Drives: 22 ZL1 1LE
Normal GM engine ticking. Nothing to worry about good sir
Gen_Nick3.8 is offline   Reply With Quote
Old 02-26-2016, 03:03 AM   #3
asimpleguy
asimpleguy's Avatar
Drives: 2016 Camaro 2SS
The ticking is a normal. Its a result from the direct injecting. Nothing to worry about
asimpleguy is offline   Reply With Quote
Old 02-26-2016, 07:15 AM   #4
TheCaptain
N7 Spectre
TheCaptain's Avatar
Welcome to the world of Direct Injection!
Old 02-26-2016, 07:18 AM   #5
Bluecyclone
Bluecyclone's Avatar
Drives: 2014 Cyclone mustang
Buy a UPR "catch can" as DI will produce lots of "blow-by".
2014 Cyclone/Select Shift/"/Sold
2016 ruby red GT w/3.55:1/resonator delete X- pipe/UPR catch can/Airaid "tube"W/AEM/J&M/BigWorm/BMR /SVE /ZL1addons/Redline/Steeda/BG fluids/
Bluecyclone is offline   Reply With Quote
Old 02-26-2016, 07:51 AM   #6
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
On a test drive I heard the same sort of ticking in a '15 Silverado 5.3L with direct injection. I know it's normal, but certainly don't like it.
nancygrl is offline   Reply With Quote
Old 02-26-2016, 08:18 AM   #7
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
really? And connect it where? I've looked and I dont see any external hoses that look like pcv hoses. I've taken apart the intake up to the throttle body and it's bone dry and perfectly clean. So it would be great if you could identify where such a can should be installed and the oil it would be catching.
cellsafemode is offline   Reply With Quote
Old 02-26-2016, 08:20 AM   #8
KMPrenger
KMPrenger's Avatar
DI is not the cause of the blow by. Its just that DI doesn't clean the blow-by like port injection does.
Old 02-26-2016, 09:35 AM   #9
cellsafemode
Still, this assumes there is blow-by to clean in the lgx. I've yet to see any evidence of it.
All I've seen is GM saying the lgx has an improved oil-air separator mechanism (somewhere) that performs 3x as good as the lfx's.
Nobody has identified where a catch can would be installed yet much less if it's even needed on the lgx.
