12-15-2017, 05:23 AM | #57 |
ZL1 launch issues
+1 please fix this, at a drag strip it is very embarrassing!!
12-15-2017, 05:39 AM | #58 |
Drives: 2017 Black ZL1 (6spd) Join Date: Dec 2016
+1
Not to mention it's embarrassing in front of friends when leaving gatherings. FYI, I feel that the eLSD system is engaging too much at all times. You can be at 20 mph in 4th gear hit the throttle and it reads 19% wheel slip. That part doesn't make sense to me and I think that slows down my power across the whole power band. I also found out that there is some procedure about bleeding the ICHE system that engineering recommended that my dealership do to my car. It does seem a little better since they did this but I can't tell for sure as it's too cold in the northeast to really test the system until spring time. |
12-15-2017, 06:04 AM | #59 |
I have problems with this as well.
12-15-2017, 06:18 AM | #60 |
+1. I would like an explanation of this as well, especially now that I'm past break-in.
Thanks
12-15-2017, 06:20 AM | #61 |
Drives: 2015 Ultimate Track SS Join Date: Apr 2015
I'm in......
2015 2SS Ultimate Track Camaro
https://www.racingjunk.com/news/2014...ack-camaro-ss/ 2016 2SS M6, MRC, NPP, Nav, Sunroof -- SOLD 2010 2SS/RS M6 -- SOLD |
12-15-2017, 07:09 AM | #62 |
Drives: 17 NFG ZL1 17 GTR 22 RS6 Join Date: Apr 2017
+1 this thread, even as an A10 owner Id like to know more.
12-15-2017, 07:52 AM | #63 | |||
corner barstool sitter
Zach - read on. Quote:
Nothing about tire performance is "linear", let alone "constant". All or nothing behavior is for doorbell switches. You'd really like to be able to stay right at that peak the whole time you're accelerating but doing so is probably beyond human capability. If anything, your feedback loop from sensing a little too much slip and lifting ever so gently - or not sensing enough and adding a little throttle - is simply too slow. Quote:
But I do want to understand what's going on behind the curtain even if all that does is confirm or deny my own suspicions and maybe point me in some direction for how to best cope with it. I'm not going to assume that this particular piece of technology will remain exclusive to the ZL1 and cars of similar performance capability. Norm
12-15-2017, 08:03 AM | #64 | |
Bring It
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold 2010 Camaro SS - 650RWHP Daily Driver - Traded |
12-15-2017, 08:08 AM | #65 |
+1
12-15-2017, 08:19 AM | #66 |
Drives: 68 Camaro Join Date: Jun 2017
+1 I actually had significant bogging happen in 2nd gear, too. Its driving me nuts and making me regret getting an M6, which is really crazy because my 67 Nova wagon and 68 Camaro are T56 cars because they are my favorite.
12-15-2017, 08:40 AM | #67 |
Drives: 18'-1LE Join Date: Jul 2017
+1 here as well...
ZL1 A10 owners be like, hey little brother (1LE), one day you to can run with the big dogs! |
12-15-2017, 08:58 AM | #68 |
Ankh599
Drives: 2017 Camaro ZL1 Join Date: Feb 2013
You my vote. I don't think you need to change anything.
I've met with the corvette tech at my dealership and he stated GM wanted the car drivable even for grandma. He says he cam put a tune on it that can eliminate the bogging down. Once I have mine done I'll report back |
12-15-2017, 09:09 AM | #69 | ||
Drives: '17 ZL1 Join Date: Jul 2016
The proof is in the case when the car first begins to accelerate. Since the car isn't moving, any slip of the tires will exceed the 15% of allowable slip. Trying to keep the slip limited to 15% at low speeds will require significantly reduced engine power at the worst possible time. By the time the car gets going fast enough for the 15% to become meaningful/stable, it's too late for launch control to provide value. Although maybe not a perfect solution, I would think a distance-over-time (e.g., MPH) target slip metric would at least not have this issue. I'm really hopeful we can get the Camaro team to help explain their rational for their design. |
12-15-2017, 09:48 AM | #70 | |
And thanks for that info. Tony |
