04-06-2024, 09:54 AM | #1 |
Complete fluid change
I am looking for some help please, I am bringing my 2013 ZL1 out of storage here in WI and I am changing all the fluids with top of the line Amsoil. Does anyone have a reference guide to the amount of fluids needed for:
Antifreeze Rear Differential fluid Brake fluid Transmission fluid Thank you in advance for the help!! |
04-06-2024, 12:00 PM | #2 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
Got your owner's manual? It's in there.
Page 12-2.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
04-06-2024, 09:58 PM | #3 |
Drives: Camaro 2SS Gen 5 Join Date: Oct 2023
Amsoil is not "Top of the Line". It shows the exact same wear metals in the exact some concentrations as any other quality oil that cost's 50% less....
Is it good oil? Sure. Does it live up to all the hype and cult following? No. |
04-07-2024, 12:16 AM | #4 |
Give speed a chance
Here's 3 outta 4 from the Chilton manual. For brake fluid 2 (maybe 3) 12oz bottles should suffice if you're doing a flush. If just a quick bleed than just 1 should be ok. Your car does have the big Brembo calipers so you may want wait for someone to chime in that has flushed in DOT 4 for track use, they'd have an exact amount they used.
04-07-2024, 12:58 AM | #5 |
04-07-2024, 02:54 AM | #6 |
It don’t come easy.
Think the OP is saying their using the high tier version of Amsoil. Like Signature series. But, thanks for lettings us know it’s over hyped and has a “cult following”.
04-07-2024, 12:11 PM | #7 |
Drives: 2013 camaro 2ss 1le Join Date: May 2020
does the tr6060 capacity spec include the cooler and lines (essentially "dry") or just a drain and fill? going to clear out the cooler too next change so curious how much i should add afterwards, especially since its basically impossible to get even a gallon into the case at a time from past experience.
2013 Camaro 2SS 1LE w/ RS [Rally Yellow]
Stock + Speed Engineering 1 7/8 LTHs w/ TSP HFCs, Roto-Fab CAI, Innovate DLG1/LC2 Dual WBo2, Smoked Wicker Bill, Self Tuned w/ HPTuners Last edited by daktah; 04-07-2024 at 12:22 PM. |
04-07-2024, 12:30 PM | #8 | |
04-21-2024, 02:08 PM | #9 |
so the capacity spec DOES include the lines and cooler? so if i were to drain the transmission, lines and cooler it would take the full 4.whatever quarts to fill everything back up and be at the correct level in the mt case?
Stock + Speed Engineering 1 7/8 LTHs w/ TSP HFCs, Roto-Fab CAI, Innovate DLG1/LC2 Dual WBo2, Smoked Wicker Bill, Self Tuned w/ HPTuners |
04-24-2024, 03:51 PM | #10 |
Just checking if someone has changed the brake fluid, how much did it take to replace please
