dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Florida
Old 06-16-2014, 06:36 PM   #1
xTHExxFALLENx
xTHExxFALLENx's Avatar
Drives: 2010 RS / 2017 SS
Shops for halo installation?
Hello everyone, where can I go to pay to install the color shift halos from AAC in South Florida? Also how much do you think it will cost? Thanks in advance.
xTHExxFALLENx is offline   Reply With Quote
Old 06-16-2014, 08:05 PM   #2
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
Drives: 2017 HBM 2SS Convertible A8
I am sure an arm and a leg you would be better off buying the NightOwel kit and doing it yourself I did mine 2 weeks ago no needing to bake your deadlights.
#TeamBeckyD
**FIFTY HBM 2SS VERT**
01pewterz28 is offline   Reply With Quote
Old 06-16-2014, 08:19 PM   #3
xTHExxFALLENx
How is it easier?
Old 06-17-2014, 05:24 AM   #4
01pewterz28
#TeamBeckyD
Originally Posted by xTHExxFALLENx View Post
How is it easier?
The night owl kit you remove the headlights and pop open the two access panels and remove the factory LED, and replace it with the Night Owl LED. Next close up the 2 panels one is held on by 3 screws, he other panel you just is a screw open panel. Connect the wiring harness for each lights, mount the control box and you are good to go.
With the method you are going to go, you need to remove the headlights, then bake them, break the rubber seal to open them up (split the lights apart), next replace the entire OEM halo ring with the AAC LED ring, run your wires, use the existing rubber real (make sure it’s prefect no gaps) bake the lights in the oven again to make sure you have a perfect tight seal. Put the headlight back in run the wires and you are good to go.
I prefer the look of the stock halo ring and not the replaced AAC LED halo.
I had the JDB RGB halo kit, and replaced it with the Night Owl kit two weeks ago and I am doing my friends kit in a few weeks. All in all about 3 hours of work if you are doing it by yourself (removing the wheels, liners, bumper, headlights, LED, ect...)
Have a look at the Night Owl RGB halo kit hundreds of colors, smart phone app, wifi, ect...
#TeamBeckyD
Old 06-18-2014, 02:39 PM   #5
ka1
ka1's Avatar
Drives: 2011 2SS
yeah Nightowl is the way to go. The ACC kits costs less but you will make up that cost in installation.
ka1 is offline   Reply With Quote
Old 06-18-2014, 11:06 PM   #6
Erik@lashway
Erik@lashway's Avatar
Drives: Camaros, Vettes, Trucks
Try Sullys Detailing, or Superior Auto Design. Both in Pompano.
Erik@lashway is offline   Reply With Quote
aac halos 2.0 color shift, installation, installer, miami, shops
