Vararam
Old 07-14-2017, 12:19 AM   #1
intensifi
Drives: '12 2LT Convertible
Question Corvette c7 front license plate bracket on ZL1?
Hello,
Does anyone know if the C7 license plate bracket will mount and be secure in the lower grill of the ZL1?
I'm trying to avoid putting 4 holes in my new bumper.
Thanks in advance!
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 07-14-2017, 02:10 AM   #2
STUNNAH
"BEASTM*DE"
STUNNAH's Avatar
Drives: 2013 ZL1 Black
You may as well but it where it is supposed to be located...Chances are if you don't you'll get a citation for improper display of the license plate...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S...
Dual 10" Kicker Comp S Subs 1200w...
STUNNAH is offline   Reply With Quote
Old 07-14-2017, 03:18 AM   #3
gmjj13
gmjj13's Avatar
Drives: 2015 ZL1
I've used the sto n sho baracket and have had no problems. I didn't want to drill holes in my bumper either. It mounts under the front splitter. I'm not lowered and have had no issues with clearance.
http://shop.bigmikesperformanceparts...-ZL1-SNS26.htm
2015 ZL1
1952 Chevy Pickup
gmjj13 is offline   Reply With Quote
Old 07-14-2017, 09:09 AM   #4
intensifi
Did you drill holes in the support or reuse existing holes?
Since I don't have a belly pan (yet) I'm thinking I could put nuts and washers to hold a bolt better than just screwing into plastic.
Old 07-14-2017, 09:52 AM   #5
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Hey, just a friendly tap on the shoulder, maybe your profile info is out of date but looks like you have an SS and you're posting in the ZL1 section. The ZL1 and SS front end and mounting stuff is completely different except for the screw in OEM license plate mount. There's probably a lot more traffic in an SS section.
Can'tHave2MuchHP is offline   Reply With Quote
Old 07-14-2017, 10:59 AM   #6
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
Sounds like he swapped the ZL1 front onto his SS.
jayno20 is offline   Reply With Quote
Old 07-14-2017, 12:19 PM   #7
intensifi
Yep new front end. And to be completely clear, car will not be badged as ZL1.
Simply asking in ZL1 forum as new front end is factory ZL1 component set.
Old 07-14-2017, 12:33 PM   #8
Can'tHave2MuchHP
Drives: Fast
Oh alright, cool. Can't help with a C7 item, doubt anyone has done it but I know that Phastek carries a few options, I think they even make one that can go on the front tow hook (If you have that installed).
Old 07-14-2017, 01:45 PM   #9
TOO.BAD
TOO.BAD's Avatar
Drives: 2013 ZL1 M6 Convertible
jacfab.com/products/camaro-products/license-plate-bracket/
Here is a good option for a 5th Gen ZL1 License Plate that you don't have to drill holes in your car.
Mild to Wild Switch, Roto Fab CAI, Big Gulp, Washer Relocation, Ported Throttle Body, Rough Idle Road Race Cam, Supporting Valve Train Upgrade, Dynatech Long Tube Headers Ceramic Coated and High Flow Converters, Injector Dynamics 1025 cc, 22.5%Overdrive Balancer Pulley, Fuel Pump Voltage Booster, Moroso Catch Can.
Jannetty Installed and Tuned.
675 RWHP 630 RWTQ 11.325 1/4 Mile Time @ 124.53 MPH
TOO.BAD is offline   Reply With Quote
Old 07-14-2017, 04:46 PM   #10
intensifi
I sent Jason an email last week but no response. Wondering if he is still in business.
Old 07-14-2017, 10:44 PM   #11
intensifi
Just tried the C7 bracket. It won't fit. It is actually bigger.
That said the Gen6 SS bracket looks promising. It attaches directly to the lower grill of the SS.
Old 07-15-2017, 10:59 AM   #12
jrhagen
Drives: Camaro
Check Jacfab.
http://jacfab.com/products/camaro-products/
jrhagen is offline   Reply With Quote
Old 07-15-2017, 04:07 PM   #13
z28lt1
Drives: 2014 ZL1
Think I posted this before. Top Flight C6 bracket, upside down. I drilled two holes in the bracket (not the car) and used the existing splitter screws to mount.
z28lt1 is offline   Reply With Quote
Old 07-15-2017, 04:36 PM   #14
DrLove38
DrLove38's Avatar
Drives: 2013 Black SS/RS
Originally Posted by jrhagen View Post
Only way to go for me
DrLove38 is offline   Reply With Quote
