11-16-2023, 05:49 PM | #1 |
Drives: 2017 ZL1 Join Date: Aug 2020
Adding sc to the tow truck /fueling question???
2018 Denalli 1500 w/6.2. Currently has tune, headers, 3.73 gears and a Tx Speed stage 1 cam (after the dod ate the cam).
Thinking of adding a Whipple 3.0 sc and wanting to make sure I’ve got the fueling covered. TxSpd says the cam has a 38% fuel lobe. Rwhp should be 650-675. Anyone know if this would have enough fueling capacity to not have a problem? |
11-16-2023, 06:03 PM | #2 |
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
Is it an LT4 or LT1 engine? If it's LT4, the stock fuel pump should handle all that but you would probably want to throw a JMS on it or something the likes if you want to handle E85 on it.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% Pulley, NGK HR7 Ruthenium spark plugs, Katech Oil Pump, LME tensioner, DOD delete, Cam, MPI lid, Soler ported 87mm (91mm effective) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, Borla X pipe, AFe NPP exhaust, Black Widow Angry Housewife/ Venom 250 mufflers, BMR engine mounts, Banks iDash, Lithium Battery, Course Motorsports phone mount, AEM X- Series, HP Tuners, JMS, E85, 13.6 psi
737 HP/ 779 TQ |
11-17-2023, 07:54 AM | #3 | |
I don't believe GM put LT4's in any trucks...the 2018 truck 6.2 is a L86 similar to the LT1.
2016 NFG 1SS A8
11-17-2023, 09:07 AM | #4 |
I think the injectors and HPFP will need to be upgraded. Maybe King can chime back in but I swore the L86 fueling was even smaller than LT1 fueling.
11-17-2023, 11:28 AM | #5 | |
This gentleman will need an LT4 pump and injectors. And We stock them. Ted.
www.jannettyracing.com
11-18-2023, 08:45 AM | #6 | |
2016 NFG 1SS A8
11-18-2023, 12:09 PM | #7 |
