Go Back   CAMARO6 > Technical Camaro Topics > Cosmetic Maintenance - Wash, Wax, Detailing, Exterior Repairs
AWE Tuning
Old 10-29-2020, 06:18 PM   #1
Hulkamaniac
Livin' the Dream
Hulkamaniac's Avatar
Question Battery Tender Hook Up???
Dumb question... where do I hook my battery tender up on my 2017 Camaro 2SS? Is it safe to hook it up here? Which black wire is the ground? See picture below.
Normally, I'd just unhook the battery for storage, but I've got a 3 car garage now so I don't have to store it in a storage locker.
Thanks for your help!
Hulkamaniac is offline   Reply With Quote
Old 10-29-2020, 08:26 PM   #2
Dragon08
Dragon08's Avatar
Drives: 2020 1LE
I hooked my positive up to one of the empty ports there. I used #4. That whole terminal is positive. Your multimeter will confirm that.
For the negative lead on my tender, I hooked it to the ground lug that is just in front of the fuse box. Can't see it in your picture, but you can't miss it. Its the large post that is connected to the inner rail. I think its 13mm, not sure?
BTW, not a dumb question. I did a search a couple weeks ago for the same info and didn't come up with a clean answer to the same question you had. I know its out there, but it didn't float to the top for me either.
The other option is to hook up to the battery terminals direct. I am trying this out this year as it was the easiest route. I have a pigtail that is now part of the vehicle. I assume you are doing the same.
Dragon08 is offline   Reply With Quote
Old 10-30-2020, 08:17 AM   #3
Hulkamaniac
Livin' the Dream
Thank you Dragon!
I will be looking for the ground and use #4 like you did for the positive side.
However, I need to get slighter larger eye hook up as mine are a tad too small to go around the studs.
I didn't want to hook up directly to the battery just for the simple fact it's in the trunk.
Old 10-30-2020, 11:01 AM   #4
Dragon08
Dragon08's Avatar
Drives: 2020 1LE
Originally Posted by Hulkamaniac View Post
Thank you Dragon!
Yep. I just kinda snake the wires out of the back of the engine compartment to the tender. Hopefully it will work out just fine.
Here is the pigtail I have on my car:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 10-30-2020, 11:45 AM   #5
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
I hooked the positive cable to one of the positive posts just as Dragon did. I hooked the negative cable to the top of the negative battery cable. There is already a small post there that another wire harness is connected to.
Mark114 is online now   Reply With Quote
Old 10-30-2020, 10:59 PM   #6
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
This may help...
https://www.camaro6.com/forums/showthread.php?t=540177
1hprush is offline   Reply With Quote
Old 10-31-2020, 12:59 AM   #7
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Pardon my ignorance, but is there any reason to not use the post under the positive cover? Or are you guys talking about bolting up something more permanent?
I am storing my car away for winter soon, so curious as well.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 10-31-2020, 04:59 AM   #8
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
Or you can use "transport mode". I always use this when storing my car for long periods, it's similar to removing the negative terminal:
https://www.camaro6.com/forums/showthread.php?t=454614
MakCamaro is offline   Reply With Quote
Old 10-31-2020, 04:46 PM   #9
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
I always use that post to hook up the trickle charger, no issues at all so far, the charger works and the car starts up like a charm after winter. This year I'll also give transport mode a try .
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 11-01-2020, 11:55 AM   #10
Hulkamaniac
Livin' the Dream
Talking
Here's what I did, thanks to Dragon.
I hooked up to #4 terminal and grounded to the ground stud on the frame.
Then ran the cord through the front grill and protected the paint with a microfiber cuz the car will be covered after I clean it up this week.
I use a Schumacher 1.5 Amp Speed Charger which is also a controlled trickle charger. It's idiot proof too, it will not charge if you're hooked up backwards. I bought it 9 years ago when I first stored my 2011 Camaro 2SS. It was $29 at Wal-Mart.
Old 11-01-2020, 10:05 PM   #11
Dragon08
Dragon08's Avatar
Drives: 2020 1LE
You nailed it. Love that green!
