BeckyD @ James Martin Chevy
Old 02-20-2017, 10:06 AM   #1
Tran
Administrator
Tran's Avatar
Drives: 2010 Camaro of course....
Thumbs up Official Camaro ZL1 Top Speed: 198 MPH!
CAMARO ZL1 GOES FOR 200 MPH
Fastest Camaro ever rips hole in the air at Germany’s Papenburg High Speed Oval
2017-02-20
DETROIT
— Slide over to the next lane. The Camaro ZL1 Coupe has a top speed of 198 mph (318 km/h).
Chevrolet tested the max velocity of the ZL1 (with 10-speed automatic) on the High Speed Oval at Germany’s Automotive Testing Papenburg GmBH proving ground. Compensating for wind speed, the top speed is the average achieved from running the ZL1 in both directions on the 7.6-mile (12.3 km) loop — 202.3 mph in one direction and 193.3 mph in the other direction.
“This test caps an impressive list of performance stats for the Camaro ZL1, which was designed to excel at everything,” said Al Oppenheiser, Camaro chief engineer. “It’s the most capable — and fastest —Camaro ever.”
The Papenburg testing was conducted on the ZL1’s production Goodyear Eagle F1 Supercar 3 tires with pressure set at 44 psi, the recommended setting for extended high-speed driving. The car’s only deviations from stock were mandatory safety equipment and data logging equipment.
Papenburg’s high-speed oval features 2.5-mile (4 km) straights and 1.3-mile (2.15 km) turns with 49.7-degree banking on the top lane. The steep banking allowed Chevrolet test drivers to run the ZL1 flat out around the track without lifting off the throttle in the turns.
“The ZL1 was developed with high-speed performance in mind, incorporating a balanced aerodynamic package that reduces lift without significantly affecting drag,” said Oppenheiser. “After testing the car in standard settings, which produced the 198-mph average, we set the front and rear camber adjustments to 0 degrees and the tire pressures to the maximum allowable sidewall pressure, and saw the ZL1 average over 200 mph.”
Special aero features include a stanchion rear spoiler that offers an advantageous lift/drag ratio compared to a blade-style rear spoiler, and a patent-pending auxiliary transmission oil cooler cover that reduces front-end lift with no drag penalty. The front-to-rear aero balance was also fine-tuned for high-speed stability.
Additional performance capabilities of the ZL1 Coupe tested with the available 10-speed automatic transmission include:
  • 0-60 mph in 3.5 seconds
  • Quarter mile in 11.4 seconds at 127 mph
  • 1.02g max cornering
  • 60-0 mph braking in 107 feet (35 meters).
The 650-horsepower, supercharged LT4 engine powering the ZL1 is matched with a standard six-speed manual transmission with Active Rev Match or an available, all-new 10-speed automatic transmission. Additional features include:
  • Magnetic Ride Control
  • Electronic limited-slip differential (coupe only)
  • 20-inch forged aluminum wheels
  • Goodyear Eagle F1 Supercar 3 summer-only tires measuring 285/30ZR20 in front and 305/30ZR20 in the rear*
Brembo brakes with six-piston Monobloc front calipers and two-piece rotors
The 2017 Camaro ZL1 starts at $63,435 for a coupe with the manual transmission (price includes $995 destination and $1,300 gas guzzler tax) and $65,830 for a coupe with the 10-speed automatic (price includes $995 destination and $2,100 gas guzzler tax).
Tran is offline   Reply With Quote
Old 02-20-2017, 10:13 AM   #2
DenverTaco07
DenverTaco07's Avatar
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot
sweet, thanks!
DenverTaco07 is offline   Reply With Quote
Old 02-20-2017, 10:17 AM   #3
SSport16
SSport16's Avatar
Drives: 2016 Garnet Red Camaro 2SS
Damn! Over 200, nice!
2SS Camaro, Garnet Red, Adrenaline Red, NPP, MRC, A8, 5 Split Spoke Bright Silver Wheels (56W)
1100 Status - 7/24/15 (Ordered)
3800 Status - 10/13/15 (Built)
6000 Status - 12/22/15 (Delivered)
SSport16 is offline   Reply With Quote
Old 02-20-2017, 10:23 AM   #4
HyperBlueX2
HyperBlueX2's Avatar
Drives: '22 Silverado 2500HD Duramax LTZ
Oh Yeah!!!!!!
HyperBlueX2 is offline   Reply With Quote
Old 02-20-2017, 10:23 AM   #5
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
What about the standards? No verification on them?
KLR ZL1 is offline   Reply With Quote
Old 02-20-2017, 10:28 AM   #6
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Old 02-20-2017, 10:31 AM   #7
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Hot Damn!! 202!!
Old 02-20-2017, 10:43 AM   #8
NB2017ZL1
NB2017ZL1's Avatar
Drives: 2017 ZL1 10 Speed Hyper Blue
Wow. Just wow. So proud to be part of this !
2017 ZL1
NB2017ZL1 is offline   Reply With Quote
Old 02-20-2017, 10:48 AM   #9
JoeP@TeamBeckyD
JoeP@TeamBeckyD's Avatar
...WoW!..
Becky
Old 02-20-2017, 10:50 AM   #10
NB2017ZL1
NB2017ZL1's Avatar
Isn't that faster than the Z06 GM claimed top speed ? I could be wrong but if so the Z06 guys are gonna be pissed again.. First their motor , then the first A10, now faster top speed. Can't be. I have to be wrong.
2017 ZL1
Old 02-20-2017, 10:58 AM   #11
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Nice.
Mods:
Old 02-20-2017, 11:07 AM   #12
Mr. Wyndham
No, I think you're right. And the secret is in the aero...they mentioned that stanchion spoiler...for all that people gripe and moan about how it looks...the fact of the matter is - the Z06 has a giant parachute on the back of it to generate downforce...the ZL1 uses what amounts to an upside-down airplane wing...same push...less drag....a LOT less drag. And the evidence is here.
Plus, keep in mind the Gen 6 ZL1 has less (I think 2%) frontal area than a Gen 5 ZL1. That's significant when you reach these sorts of speeds.
Finally, the car has all sorts of strakes, scoops, chutes, and covers to reduce lift and drag at high speeds.
ZL1 is the real deal!!
Old 02-20-2017, 11:12 AM   #13
NB2017ZL1
NB2017ZL1's Avatar
Wow. Just wow !!
2017 ZL1
Old 02-20-2017, 11:14 AM   #14
snackbar64
snackbar64's Avatar
Drives: SW 2017 ZL1, M6, Carbon, Nav, MR,
My God!! This brings up an interesting question. Can this transmission really be 29 mph faster than the M6?
snackbar64 is offline   Reply With Quote
