BeckyD @ James Martin Chevy
Old 09-13-2016, 12:32 PM   #1
Tran
Administrator
Tran's Avatar
Drives: 2010 Camaro of course....
Arrow Ten Interesting Facts About New Camaro ZL1's 10-Speed Automatic (A10)
Via Road & Track
Name:  gallery-1473182681-35-liter-ecoboost-engine-and-10-speed-transmission-876x535.jpg
10 Things to Know About Ford and GM's 10-Speed Automatic
The new 10-speed gearbox will appear in the Ford Raptor and the Chevy Camaro ZL1. It's a high-performance box with a lot of gears.
This new 10-speed rear-drive transmission is the result of collaboration between Ford and General Motors, although Ford had the engineering lead on it. The companies also are jointly developing a nine-speed transverse automatic for front-drive cars and crossovers; GM is leading the engineering on that effort. Not long after Ford starts cranking out F-150s with these transmissions, Chevrolet will launch it in the 2017 Camaro ZL1, coupled to the 650-hp, supercharged 6.2-liter LT4 engine from the Corvette Z06. With a torque capacity of at least 650 lb-ft, this first version of the transmission is plenty beefy to handle that track-ready machine, as well as the Ford Raptor, with its uprated 3.5-liter EcoBoost V-6 making upwards of 450 horsepower—maybe more. We would expect that soon afterward, we will see this design spawn a family of 10-speed automatics that are smaller and lighter to suit less-hunky rear-drive machines in the Ford and GM families.
1. Packing More Gears Into the Same Ratio Spread
As you'd expect, Ford's new 10R80 10-speed automatic has a wide spread of ratios between first and tenth gear. However, the overall span of 7.384 is not the widest in the business—not by a long shot. There are at least five conventional automatics, including some eight-speeds, with a wider spread. The widest is the front-drive ZF 9HP series with nine gears, as found in the Jeep Cherokee, with a total spread of 9.819. Porsche's PDK seven-speed dual-clutch gearbox used in the Panamera goes even further with a maximum spread of 10.119. According to Kevin Norris, Ford's manager of the 10R programs, in the applications planned for this transmission, extensive simulations indicated that there was no benefit in a span wider than 7.4. And with a top gear that isn't excessively tall, it's possible to stay in that gear more often at highway speeds, something that we've found nearly impossible to achieve with the Jeep Cherokee's tall ninth gear.
2. More Gears to Keep the Engine in its Ideal Rev Range
Arithmetic dictates that if the 10-speed transmission does not have a particularly wide overall ratio spread, than the individual gear spacing must be fairly close. Sure enough, with the 10R80, the average rpm drop during a shift is only 20 percent, while it's 25 percent in the ZF eight-speed found in cars across the industry, and 32 percent in Porsche's seven-speed PDK. This new 10-speed has closer ratios, on average, than the version of the seven-speed PDK in the latest 911 GT3. The tight ratios keep the engine closer to peak power during full-throttle acceleration and, according to Norris, provide for smoother operation when towing a trailer, a matter of some importance in the F-150 world.
3. Close-Ratio Overdrives
Tenth gear in the 10R80 transmission has an overdrive ratio of 0.636. Ninth is 0.689. That's a drop of only eight percent, making for a nearly imperceptible 10-to-9 downshift when needed. While Norris promises that tenth gear is a genuinely useful gear in the F-150 and the transmission will stay in that gear over a wide range of highway conditions, the close ninth ratio helps when the truck is heavily loaded or towing a substantial amount. The transmission also offers "Tow/Haul" and "Sport" modes, which also usefully employ the ninth gear—almost as an alternative top gear. Eighth gear also is an overdrive, with a ratio of 0.854.
4. It Keeps the Revs Very Low, to Keep the EPA Happy
Though much of the initial hype about this transmission centers on its installation in Ford's upcoming new Raptor and the Camaro ZL1, it will first go on sale in the 2017 F-150 that's coupled to the upgraded version of the Ford 3.5-liter EcoBoost V6, which now makes 375 horsepower and 470 lb-ft of torque. The 10R80 will be standard equipment with that engine and its close ratios nicely match the engine's copious low-rpm torque. On the EPA city cycle, the F-150 with this powertrain never sees engine rpm exceed 1450 rpm. In other words, plan to get much worse real-world fuel economy. Although, when you step into it, Ford claims the transmission and engine controls coordinate carefully to avoid situations where the engine comes onto boost exactly when the transmission downshifts, thereby providing a larger jolt of acceleration than the driver wanted.
5. It's Nearly the Same Size and Weight as the Six Speed
Thanks to the use of four simple planetary gearsets, controlled by six clutches, the 10R80 is only about an inch longer and four pounds heavier than the 6F55 transmission currently used with the 3.5-liter EcoBoost V6. This required very careful attention to detail in the design of each component. For example, the torque converter in the transmission (pictured above) is about 0.4 inch thinner and two pounds lighter than the one in its predecessor. Part of the weight reduction comes from an aluminum stator support, a formerly cast-iron part. In fact, the new transmission has no cast-iron parts whatsoever.
6. It's All About the Hydraulics
The clutches in an automatic transmission are hydraulically actuated and controlled, so the new transmission relies on two special pumps to provide the necessary hydraulic muscle. The main pump is an off-axis design with variable displacement. Removing the pump from the transmission's main shaft reduces overall length; the variable-displacement capability means that the pump's output can be adjusted to the transmission's needs, reducing the power that the pump absorbs. A second, electrically driven hydraulic pump allows idle-stop capability. The electrically driven pump is both more reliable and more compact than a hydraulic accumulator, while using very little power.
7. This Ain't Your Granddad's Automatic Transmission Fluid
Just as engine oil seems to get thinner every year, so does transmission fluid, in search of reduced friction. Back when four-speed automatics were the norm, transmission fluid had a viscosity of around 7.5 centistokes. The Ford six-speed uses fluid with a viscosity of 6.0 centistokes. The new 10-speed drops that to about 4.5 centistokes, reducing both friction and the workload of the hydraulic pumps. The new fluid is called Mercon ULV, and is planned to last the lifetime of the transmission, aided by a new filter that has two levels of high-efficiency media and a pleated design with much greater area than the filter in the current six-speed transmission. It also helps that the transmissions are assembled in factories that set new industry standards for cleanliness.
8. Shifts Faster Than Porsche's PDK, Says Ford
With a low first-gear ratio of 4.696, the torque converter basically aids in a smooth launch, then quickly locks up and stays that way. Shifting is controlled by the six clutches, which engage and disengage two at a time to swap cogs swiftly and smoothly. These shifts do not require the torque converter to unlock, which would decrease efficiency. These clutches are controlled by integrated solenoid valves, which respond more quickly than the usual two-piece designs. The system has also been designed to minimize the length of the hydraulic passages and optimize the clutch designs for quick fill times—all in the interest of faster and more responsive clutch operation. Although we're skeptical, and these kinds of claims are heavily dependent on exactly what constitutes the start and end of a shift, Ford claims transmission shifts 26 to 36 percent more quickly than Porsche's PDK, at least through fourth gear. The transmission can also perform large, multi-gear downshifts—directly from tenth to fifth, or ninth to fourth—smoothly and rapidly. There's also a one-way clutch, which smoothly and cleanly disengages the transmission when rolling to a stop, avoiding a potentially jarring 3-1 downshift.
9. It's All About Minimizing Friction
In addition to the efficient hydraulic pumps and the low-viscosity fluid, there are other measures to reduce the transmission's mechanical friction. For example, instead of flat thrust washers, the 10R80 uses ones fitted with radial needle bearings, replacing sliding friction with the lower rolling variety. Even the multi-plate clutches get tiny springs which push the plates apart to minimize their drag when they are not engaged. As a result, the new transmission is more efficient in each of its gears than the six-speed it replaces.
10. What Kind of MPG Improvement? That Depends
For all of these improvements in friction reduction, low-viscosity fluid, and the multiplicity of gears, Ford is only claiming very modest fuel economy improvements for the new transmission. Compared with the existing six-speed automatic, Ford suggests a 3-percent-to-4-percent gain—barely a single mpg in the case of the F-150. That's very odd, because when ZF introduced its eight-speed automatic, the company claimed an 11-percent fuel-economy improvement over its existing six-speed automatic. Aisin claimed a 6.6-percent-to-7.0 percent improvement with its eight-speed automatics, while Mercedes suggests a gain of up to six percent when going from the 7G-Tronic to the 9G-Tronic. Ford is adding four gears rather than two, yet only expecting half as much benefit. Perhaps Ford is engaging in a serious bit of under-promising here. We would be shocked to see less than 2-mpg-to-3 mpg of improvement once the '17 F-150 is certified—especially because the truck also gets that improved version of the 3.5-liter EcoBoost V6.
Tran is offline   Reply With Quote
Old 09-13-2016, 12:41 PM   #2
Tran
Administrator
Tran's Avatar
Let's keep the discussions free of GM vs Ford topics please
Old 09-13-2016, 12:53 PM   #3
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
I think this is an important detail to note. One reason why automatics usually took longer to shift is because the TCM would need to unlock the torque converter first, then shift gears, then lock it up again if conditions were met. Being able to keep the torque converter locked essentially makes it a direct drive connection as if there were no torque converter involved. Based on this I can believe that it would be possible for the new 10 speed transmissions to shift faster than a PDK.
Nick S is offline   Reply With Quote
Old 09-13-2016, 01:03 PM   #4
DenverTaco07
DenverTaco07's Avatar
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot
2017 SS 1LE | HBM | Vortech V3-Si supercharger (620RWHP and 575ft lbs) | PDR | Black Bowties | Illuminated Front Black Bowtie | Illuminated Door Sills | Smoked Tails | vented seats mod
DenverTaco07 is offline   Reply With Quote
Old 09-13-2016, 01:13 PM   #5
MiamiBlueCamaro
MiamiBlueCamaro's Avatar
Drives: Gen 6 Camaro RS
Shifts Faster Than Porsche's PDK. Excellent news.
MiamiBlueCamaro is offline   Reply With Quote
Old 09-13-2016, 01:52 PM   #6
whiteboyblues2001
whiteboyblues2001's Avatar
Drives: 1SS, A8, MRC, NPP, Blade Spoiler
When they say it shifts faster than the Porsche PDK, is that only upshifts, or both?
whiteboyblues2001 is offline   Reply With Quote
Old 09-13-2016, 02:15 PM   #7
sdmcss
sdmcss's Avatar
Drives: 2018 Camaro 2SS 1LE, 1985 MCSS
sdmcss is offline   Reply With Quote
Old 09-13-2016, 03:21 PM   #8
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
The world may never know. At least until the comparison that I'm sure the rags will do.
KLR ZL1 is offline   Reply With Quote
Old 09-13-2016, 03:36 PM   #9
SpeedIsLife
Drives: Current Camaro-less
It sounds like this transmission is designed to be a 1:1 replacement for present 6 speed and 8 speed units, since it occupies roughly the same space.
The only reason why this wouldn't be the standard automatic is if they can't build up supply fast enough.
SpeedIsLife is offline   Reply With Quote
Old 09-13-2016, 04:13 PM   #10
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Dam admins trying to steal my thunder......lol. j/k. :
Mods:
Old 09-13-2016, 04:55 PM   #11
Zack46
Zack46's Avatar
Drives: 2018 2SS Camaro Hot Wheels Edition
Anything, about when the A10 will be available???
Zack46
2018 Camaro 2SS Orange Crush Hot Wheels Limited Edition
Power Sunroof, 8 Speed Auto/Remote Start, NPP Exhaust
Production Sequence Number 98
NEOCC Camaro Club Member
Former Ride: 2016 Camaro 2LT RS V6 Hyper Blue Metallic
Zack46 is offline   Reply With Quote
Old 09-13-2016, 06:25 PM   #12
NB2017ZL1
NB2017ZL1's Avatar
Drives: 2017 ZL1 10 Speed Hyper Blue
2017 "sometime"....
2017 ZL1
NB2017ZL1 is offline   Reply With Quote
Old 09-13-2016, 06:54 PM   #13
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
Thank you for sharing! Definitely amazing info. I am still just in shock from when I was told that A10 literally shifts up or down to another gear before the pedals click when pulled lol. Definitely fantastic technological advances!
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 09-14-2016, 09:58 AM   #14
Bobfly
OspreyTech
Bobfly's Avatar
Drives: 2016 Camaro 2SS
Quote from article
2SS Nightfall Grey Metallic w/Ash Grey Interior, Silver Rally Stripes, 6M, MRC, DPP, Nav, Sunroof & Black Bowties
Bobfly is offline   Reply With Quote
