TireRack
Old 04-28-2013, 04:08 PM   #15
JEFF75645
Drives: his wife crazy buying mods
Like this
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 04-28-2013, 04:52 PM   #16
Medi0cr3
Untamed Performance EPT
Medi0cr3's Avatar
Drives: 2011 2SS
pic is blurry :(
Night Fury Cam
Borla LT Headers and Borla Cat Back ATAK
9in. diff with 4.11's, DSS Axles, and Alum Shaft
Hurst Short-Shifter; Ideal Garage Master Cylinder
H-E Street Slayer Twin Billet Clutch
BMR: Adjustable; Trailing Arms, Toe Rods, Extreme Sway Bar. BMR Subframe Bushings.
Strange Rear Coilovers and mounts
Tuned by Rhino79
Medi0cr3 is offline   Reply With Quote
Old 04-28-2013, 04:57 PM   #17
JEFF75645
Its an S with an X through it.
Old 04-28-2013, 05:46 PM   #18
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Originally Posted by JEFF75645 View Post
Like this
That is a "weak" sensor.
Old 04-28-2013, 06:03 PM   #19
BDBiker
BDBiker's Avatar
Drives: Black 2013 2SS/RS 1LE
Learning something new every day, thanks Chase.
BDBiker is offline   Reply With Quote
Old 04-29-2013, 04:54 AM   #20
Denis
Denis's Avatar
Drives: 2010 SS
Correct me if I'm wrong. But if you have a weak sensor, it's really an issue until you start really adding more air to the motor. For example a cold air is fine. But a cold air plus a scoop and a larger throttle body might pose an issue.
Denis is offline   Reply With Quote
Old 04-29-2013, 05:24 AM   #21
Apex Motorsports
Correct. With just an intake system you might be able to get away with a "weak" MAF and you might not. It depends on the system. But pretty much anything beyond that (scoop, ported throttle body) is a sure fire bet that the "weak" MAF is going to start acting up.
Old 04-29-2013, 06:28 PM   #22
uniqueskillz
uniqueskillz's Avatar
Drives: ETMC built 700+hp Twin Turbo LS3
Another tune isnt needed one you swap out MAFs right? (If your blown)
uniqueskillz is offline   Reply With Quote
Old 04-29-2013, 11:42 PM   #23
Denis
Denis's Avatar
Drives: 2010 SS
Cool thanks!
Old 04-29-2013, 11:50 PM   #24
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
No.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
I once parallel parked a train.
axis is offline   Reply With Quote
Old 04-30-2013, 04:16 PM   #25
Apex Motorsports
Originally Posted by axis View Post
No.
What he said.
Old 05-20-2013, 08:14 PM   #26
Regio_42
Ready...Set...Gone.....
Regio_42's Avatar
Drives: 10' Camaro SS/RS "Stacy"
Mine is acting up so i placed an order on Apex saturday for a strong MAF sensor lets see if that makes my car feel different from what i read.
Regio_42 is offline   Reply With Quote
Old 06-04-2013, 05:24 AM   #27
Apex Motorsports
Thanks for your order. If you have made induction upgrades and are having any of the surging or bucking then the "strong" MAF will fix it.
Old 06-05-2013, 06:50 PM   #28
PSUsupaman
PSUsupaman's Avatar
Drives: 2011 2SS/RS Convertible
Chase, I am about to make an order on your site and just wanted to make sure that the following item is a strong MAF.
http://www.apex-speed.com/gm-mass-ai...-15865791.html
Thanks
PSUsupaman is offline   Reply With Quote
apex, bucking, maf, surging, weak
