Roto-Fab
Old 03-27-2012, 12:10 PM   #1
RiCorvette
RiCorvette's Avatar
Drives: 2017 Corvette Grand Sport 3LT
Excess oil in the PCV system; The Saga Continues
I have a Catch Can installed and it has collected over 40 oz of Oil in 6500 miles (3 oz or so every 500 mi) - I think that indicates a problem. GM, however, does not.
My dealer is agrees with me, but is approaching the issue 'by the book' and does not think they can convince GM to authorize a warranty repair using the catch phrase 'Oil Consumption' - since GM 'allows' 1qt per 2000 miles(?) as within operating parameters.
It is not a normal consumption problem, per se, since liquid oil is freely flowing through the PCV and into the Throttle Body. Imagine all that liquid oil (not oil vapor) coating the inside of the Throttle Body, Intake Manifold, Valves and Valve seats and the tops of the pistons.
I have brought this thread to the attention of my dealer, but GM remains intractable.
http://www.camaro5.com/forums/showth...t=valley+cover
Has anyone besides IndeedSS1 (OP for the above thread) been able to convince GM to warranty the Valley Cover / PCV Baffle?
If so, how was your Service Ticket written?
These are 16oz Bottles of oil collected by the Catch Can:
RiCorvette is offline   Reply With Quote
Old 03-27-2012, 12:48 PM   #2
Hannibal
Hannibal's Avatar
Drives: Camaro SS & ZL1
Doesn't look right to me. I have about that many miles on my current oil and the dipstick level hasn't moved.
Hannibal is offline   Reply With Quote
Old 03-27-2012, 03:31 PM   #3
RSBAD454
Procharged
RSBAD454's Avatar
Drives: 2010 Camaro 2SS/RS
Send a message via Yahoo to RSBAD454
http://www.camaro5.com/forums/image.php?type=sigpic&userid=23393&dateline=127333  4105
2010 ABM RS/SS with a Procharged LS3, Flowmaster exhaust.
RSBAD454 is offline   Reply With Quote
Old 03-27-2012, 04:01 PM   #4
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
not the answer you want, but why not fix it yourself? at least then you know it has been fixed.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 03-27-2012, 04:11 PM   #5
RiCorvette
RiCorvette's Avatar
I may do that once it's out of warranty, but I'd rather have it done under warranty.
Old 03-27-2012, 04:39 PM   #6
SC2150
Drives: 2012 Camaro RS, RX supercharged
The answer for all manufacturers is to have you come in every 15k miles and spend between $140 and $450 for a TB and upper indiction cleaning service so it is steady reacuuring revenue to have the owner pay to clean the deposits and oil instead of fixing the issue.
You can try and cap the valley cover vent and use the rear of the drivers side valve cover (remove the rubber cap from the barb) and it may get better. Try that and if you need more detailed instructions just ask.
SC2150 is offline   Reply With Quote
Old 03-27-2012, 04:59 PM   #7
RiCorvette
RiCorvette's Avatar
Well, The CC is doing it's job . So, other than remembering to dump it every 500 miles...
With that much oil flowing into the CC, should I be concerned that
oil is still flowing into the TB? I have an Elite Engineering CC
Old 03-27-2012, 05:01 PM   #8
RiCorvette
RiCorvette's Avatar
From our friends on a Challenger Forum:
Throttle Bodies Show Need for Catch Cans
For those who doubt the necessity for a catch can, here is a comparison between a stock throttle body with and without a catch can. The miles are not exactly the same, but close. We happen to have swapped out stock throttle bodies for BBK ones and found this interesting.
62k vs. 50k miles
No Catch Can vs. Catch Can
Old 03-27-2012, 06:13 PM   #9
BigSSexy
Drives: '10 2SS/RS LS3 Summit White
Holy cow, the oil caught from mine is about on par with yours. I've had my catch can one for ~250 miles and have caught around 2 oz. of oil. Really makes me nervous the more I read about it.
My 3 '10s:
2010 2SS/RS SW LS3
-Eibach lowering springs/Vararam/BMR Trailing Arms/EE Catch Can/Hurst/Heritage Grille/Axle back delete/SS panel/tinted windows,reflectors and tails
2010 VW Jetta TDI Cup Edition DSG
-Stock DD car
2010 Kawasaki Z1000
-Def. not stock
BigSSexy is offline   Reply With Quote
Old 03-27-2012, 06:34 PM   #10
RiCorvette
RiCorvette's Avatar
Looks like the same car, same issue: 2010 2SS/RS LS3
Did you buy the Car new or used?
If used; are you in a postion to take off the TB for inspection (easy job)
and look for oil?
Old 03-27-2012, 07:36 PM   #11
BigSSexy
Used, with about 6500 miles on it. Now almost at 7300. I'm confident I could take it off for inspection, I have the mechanical know-how to do it. Wouldn't mind getting a hold of IndeedSS and get the contact info of the mechanic that did his job.
My 3 '10s:
2010 2SS/RS SW LS3
-Stock DD car
2010 Kawasaki Z1000
-Def. not stock
Old 03-27-2012, 08:49 PM   #12
RiCorvette
RiCorvette's Avatar
[QUOTE=BigSSexy;4714705]Used, with about 6500 miles on it. Now almost at 7300. I'm confident I could take it off for inspection, I have the mechanical know-how to do it. Wouldn't mind getting a hold of IndeedSS and get the contact info of the mechanic that did his job.[/QUOT
Don't count on help from GM apparently. Dealers response:
" I opened a case with GM today regarding your vehicle. The engineer we spoke to said there was nothing they would let us change or do to the vehicle. It is performing better than any of the vehicles fixed so far. They stated the repairs listed in the bulletin would not improve the vehicles current oil usage. The amounts are all within acceptable levels for the SS. Unfortunately, our hands are tied"
BUT, they may be referring to a TSB about a blocked drain hole in the Rocker Cover. Clarification pending.
Old 03-27-2012, 09:21 PM   #13
RiCorvette
RiCorvette's Avatar
Yeah, 6500 miles and you should have a lot of oil in the TB and Manifold
if your problem is the same as mine and you are catching a lot of oil
in your CC. I installed mine at 3300 miles and I'm at 10,000 now.
The photo of the bottles of oil in the first post are from those 6700 miles.
Old 03-28-2012, 12:49 PM   #14
IMJ
IMJ's Avatar
Drives: 2012 SS LS3 | Silver Frost Metallic
Any ideas who has the best deals on these catch cans at the moment? I figure I'll install one shortly when I do my first oil change and fluid change overs.
Ironman John
IMJ is offline   Reply With Quote
IPS turbo install ipimpthisc Forced Induction - V8 119 01-01-2013 04:23 PM
This is why you get a catch can!!! BaylorCamaro Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 46 12-14-2011 08:52 AM
Can we use the catchcan made for the G8? HaZe_X Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-05-2010 10:35 AM
