Old 10-17-2017, 10:38 AM   #1
tnspd
tnspd's Avatar
Drives: 18 Camaro ZL1 1LE (WILSON)
Harness system
I finally got my new harness system hooked up. It works great. My last car had a harness bar and tank plates. That system worked fine but in my new ZL1 1LE I really did not want to mount a harness bar in it. Thanks to the help of some members in here I found a harness called the Schroth Rallye 4 ASM harness. The back seat harness mounts to the existing seat belt location bolts and the front lap belts mount under the front seat rear rail bolts. The harness can be unhooked and hidden in the back floor board when not in use. Both front and rear factory seat belts are still functional and can be used. Not expensive at all either. Now I am set for my first track day at Roebling Road in Savannah, Georgia on November 11 and 12.
tnspd is offline   Reply With Quote
Old 10-17-2017, 11:31 AM   #2
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
Nice!
2018 ZL1 1LE - Red Hot, Nav, PDR
ZL1 1LE is offline   Reply With Quote
Old 10-17-2017, 11:35 AM   #3
Hellobatman
Hellobatman's Avatar
Drives: 2017 Ford F250, 2019 Lincoln Navi
That's pretty cool!
Instagram: MattZ_L1 Vengeance Racing Built
Hellobatman is offline   Reply With Quote
Old 10-17-2017, 02:44 PM   #4
JeromeS13
Drives: 2017 1SS/1LE
Double check with your tech people with whatever organization you're running with. Some will not allow this system.
JeromeS13 is offline   Reply With Quote
Old 10-17-2017, 03:47 PM   #5
tnspd
tnspd's Avatar
I checked and they are ok with it. This is a HPDE event not racing. I remember last year a few folks had this setup. I just could not remember the name of it. This will be better than mounting the harness bar like my old setup.
Old 10-17-2017, 07:22 PM   #6
wstaab
Drives: 69 Z28, 2018 ZL1 1LE
Go to your local Chevy dealer and have parts order a seat belt extender for a 2018 Camaro. They are no charge from GM.
Cut the webbing from the part that inserts into the stock buckle.
Insert it when you are using your Schroth Rallye 4 ASM harness.
Keeps the seat belt warning system from activating.
wstaab is offline   Reply With Quote
Old 10-18-2017, 10:51 AM   #7
Squatch
Camaro pilot
Squatch's Avatar
Drives: 69 Camaro, 2014 ZL1
I cant find anything for the Camaro (or Chevy in general) on the website. Did you just use the Ford harness?
2014 ZL1 Camaro
1969 Camaro
Squatch is offline   Reply With Quote
Old 10-18-2017, 11:46 AM   #8
GhostZL1
Drives: ZL1?
Great stuff. I'll have to pick a set of those up when I get my ZL1.
GhostZL1 is offline   Reply With Quote
Old 10-18-2017, 03:02 PM   #9
tnspd
tnspd's Avatar
There is no Camaro Harness. You have to use the universal Rallye 4 ASM Harness. You cannot use the Ford harness, the buckles are different from manufacturers. Ford buckles will not fit in GM.
Old 10-18-2017, 03:04 PM   #10
tnspd
tnspd's Avatar
Thanks, I have two coming from my dealer.
Old 10-18-2017, 03:11 PM   #11
gores
Drives: 2013 SS 1LE
This is super cool! i do a lot a rec track days and slide around like crazy
gores is offline   Reply With Quote
Old 10-18-2017, 03:17 PM   #12
slick3
Drives: Garnet Red - 20 ZLE
I wonder how safe these are routed through the head rest how you have it. Is it comfortable around your neck when you are locked in? How tall are you if you dont mind me asking.
slick3 is offline   Reply With Quote
Old 10-18-2017, 03:23 PM   #13
PinHead
Drives: Duramax
Does anyone know if this will work with a HANS Device?
PinHead is offline   Reply With Quote
Old 10-18-2017, 03:31 PM   #14
Rlhay2
Rlhay2's Avatar
Drives: 2017 ZL1
I believe their website states it WILL NOT work with a HANS device.
Rlhay2 is offline   Reply With Quote
