10-16-2017, 02:10 PM | #1 |
Drives: 18 Camaro ZL1 1LE (WILSON) Join Date: Jul 2009
Rear Seat removal
Does anyone know the steps for removing the rear seat bottom from the ZL1 1LE? I googled it but nothing comes up. Maybe it is still too new.
10-16-2017, 02:13 PM | #2 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
I don’t know for sure but normally just pull up.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
10-16-2017, 02:23 PM | #3 |
Drives: 2017 Summit White ZL1 M6 Join Date: May 2017
Go to Shraderperformance.com
Instructions at the bottom of the page
Roto Fab/ Kook's LT's,ported blower,removed lid baffle/ 103mm TB' lower pulley and tune.
651/660. |
10-16-2017, 02:29 PM | #4 |
That link looks like it is for buying a rear seat delete kit. I am looking for the instructions on how to remove the seat bottom. I am not deleting the seat bottom just need to pull it out to bolt in a harness and then put it back.
10-16-2017, 02:31 PM | #5 |
I tried just pulling up but it did not work. If that is the way I will try to pull harder but want to know if that is the correct way first. Don't want to break anything.
10-16-2017, 02:34 PM | #6 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Some of the rear seat bottoms are incredibly difficult to remove. I needed two 2' crow-bars, one on each side of the snap to get my rear seat cushion off the snaps.
10-16-2017, 02:36 PM | #7 |
Drives: 6th. Gen ZL1 Join Date: Jan 2017
10-16-2017, 02:46 PM | #8 |
what tab?
10-16-2017, 03:25 PM | #9 |
1. Remove lower seat cushion: 2 clips hold the lower panel in place, near the
front lip of the cushion. Use a screwdriver or similar tool to push in to release each side. You can also lift the rear edge of cushion first, and the clips will come out this way as well. Pull lower seat cushion out of car. From the Shrader Performance page
10-16-2017, 06:24 PM | #10 | |
Drives: 2017 ZL1 10A Join Date: Sep 2017
10-17-2017, 10:15 PM | #11 |
Drives: 2017 Summit White ZL1, M6 Join Date: Jan 2017
When I took my rear seats out for racing I pulled out the top first then pull up the bottom. Really easy I thought, just 2 clips and I didn't use anything but my hands.
2011 Dodge Ram 1500 Longhorn Laramie
1966 Chevelle SS 396 |
04-09-2022, 03:06 PM | #12 |
Having FUN in the SUN...
Trying to remove mine also, and it looks like the ZL1 1LE's are different... no strap at the top to fold the seat down... can someone help shed some light on this? The back seat feels flimsy and I dont want to break it.
04-09-2022, 03:32 PM | #13 |
The ZL1 1LE does not have the strap, but the latch is the same. Here's the trick, you need to unlatch the seatback from the trunk:
04-09-2022, 04:09 PM | #14 | |
Perfect, thank you... i couldnt find that in the manual or online anywhere :(
