09-20-2017, 08:53 AM | #1 |
Drives: 18 Camaro ZL1 1LE (WILSON) Join Date: Jul 2009
Harness bar setup
Looking at options for my ZL1 1LE. What harness and harness bar setup is everyone using in their 2017 ZL1 and how do you like it? Post pictures if you can. In my 2012 ZL1 I used a Cypher Bar and harness with home made tank plates. Looking for options this time.
09-20-2017, 09:18 AM | #2 |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
Replacing the seats since no pass thru's?
2018 ZL1 1LE - Red Hot, Nav, PDR
09-20-2017, 09:19 AM | #3 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
Check with your sanctioning body's rules for using harnesses/harness bar with a factory seat...
09-20-2017, 09:25 AM | #4 |
I did they are fine with a harness bar. I just run HPDE events no sanctioned racing.
09-20-2017, 10:17 AM | #5 |
09-22-2017, 09:38 PM | #6 |
Brey krause sells one
09-23-2017, 10:16 PM | #7 |
Drives: MB 1SS Join Date: May 2017
You have to run 4 point with factory seat.
09-26-2017, 05:10 PM | #8 |
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
If you're planning to use the OEM Recaro seats, I think your best bet is to use some DOT approved 3 point harnesses like Schroth Rallye 3 ASM (anti submarine) since we don't have pass thrus on our Recaros.
I've posted some pictures in my build thread see below. It's not as ideal as a proper seat but best method for the OEM seats IMO. When not used I can simply tuck them underneath the seat and hide the back piece Note: in the picture it looks like the Y piece goes around the headrest but at the track I put it through the opening in the headrest http://www.camaro6.com/forums/showpo...&postcount=104
09-30-2017, 11:06 PM | #9 | |
Drives: 2017 Hyper Blue 2SS Join Date: Mar 2017
Where you able to get the right angle for the rear mounting belt? My understanding was you need a specific angle for that rear mount belt for it to be safe.
Hyper Blue 2SS, 6MT, NPP, 6 piston Brembo, 1LE suspensions upgrade, ZL1 Seats, Wheels & Tires
10-01-2017, 11:59 AM | #10 |
Yes, C pillar is the recommended place by Schroth. I've also used the same method with my Subaru BRZ, it's been fine since it's not creating pressure over the shoulders and keep me in my seat. I don't see any advantage of going with a harness bar over this setup if the OEM Recaros will be used (not fixed bucket seats with pass thrus)
09-09-2020, 09:54 AM | #11 |
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10 Join Date: Dec 2017
glamcem - i am looking to get a 3 point harness set up like yours - can you help with a bit more information on what parts are needed and how to attach the harness to the c-pillar? thanks a lot.
09-09-2020, 10:16 AM | #12 |
Drives: Camaro 1ss Join Date: Nov 2019
I'm running a RPM roll bar,(which fits perfect) Sparco seat and slider (will probably pull slider out for next year) Planted technologies base and Crow Harness.
I highly recommend the RPM roll bar. I cannot get a piece of paper between the top hoop and the roof. it's TIGHT
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
09-09-2020, 10:20 AM | #13 |
I don’t want to change my seats...
09-09-2020, 10:38 AM | #14 |
Drives: ISO ss 1le Join Date: May 2018
