10-18-2017, 03:40 PM | #15 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
Keep in mind, some sanctioning bodies will not allow these (NASA is the main one that comes to mind). It does not meet their requirements.
10-18-2017, 03:53 PM | #16 |
Drives: Grandad's C2 L89 Join Date: May 2017
interesting. subscribed.
2018 ZL1 1LE sw/PDR
10-18-2017, 05:09 PM | #17 | |
Drives: 2018 ZL1 1LE Join Date: Feb 2009
Can't have both. Hence why I went with the cage and full harness. This system (the OP) is a great solution for holding you in place during track driving. Much better than stock belts. Good protection for a more modest wreck. Not such a great solution if you have a significant interaction with a wall. Combination of the tracks I run and some of the wrecks I've seen, decided to go the cage and harness route. I'm actually looking to replace the stock seats with a halo seat for next season. Worst wreck I've seen personally a friend completely destroyed his GT350R in the Kink at RA and walked away. Said his Harnesses and HANS device worked perfectly, but he would not have been ok without the Halo seat (side to side head and neck protection). Like most things....its a matter of how much you want to mod, how much you want to spend, how safe you want to be.
2018 ZL1 1LE "RAZECAR" 2016 2SS Convertible "NOTOPSS" (Sold) 2015 Z/28 #306 "ITZFAST" 2010 2SS Coupe "FASSTER" (Sold) 2002 SS/RS "02FASST" (Sold) 2007 Factory Five Racing GTM "REDBLUR" (Sold) "There are two kinds of cars. Red....and everything else!" |
10-18-2017, 07:32 PM | #18 |
Drives: 69 Z28, 2018 ZL1 1LE Join Date: Jul 2017
The Schroth's Quick Fit Pro is HANS device compatible. There is a BMW model that will work with GM seat belt recepticles. Need to check the BMW model number.
Expensive, $345. tnspd how did you remove the bottom rear seat cushion to install the belts to the seat belt bolts? |
10-19-2017, 10:19 AM | #19 |
Drives: 18 Camaro ZL1 1LE (WILSON) Join Date: Jul 2009
I have only used it in fitting and testing. I have not been on the track yet. So far it feels fine to me. I believe it says to route it the way I have it. If need be I could slip it over the outside of the head rest if I feel it needs to be. I am 6 feet tall.
10-19-2017, 10:23 AM | #20 | |
10-19-2017, 10:27 AM | #21 | |
10-19-2017, 11:58 PM | #22 | |
USN VET
Drives: 2016 SS sedan, 2018 ZL1 1LE Join Date: Jun 2017
10-20-2017, 01:43 AM | #23 | |
Drives: Duramax Join Date: May 2017
10-20-2017, 09:35 AM | #24 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
Same set-up I ran in my 5th gen 1LE for autocross, the harness passed tech inspection at a SCCA National level for autocross 3 times with no issue in 2 different classes FS and CAM
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
02-14-2018, 01:33 PM | #25 | |
Drives: ZL1-1LE Join Date: Feb 2018
Quick fit pro not made for Camaro. Looking for Buckle compatibility
02-14-2018, 02:10 PM | #26 |
Drives: 1LEs Join Date: May 2009
https://www.schrothracing.com/produc...fi-ii-asm#1598
These are DOT approved (due to the buckle design), can be used with a HANS, and can be upgraded to a 5 or 6-point true anti-submarine later. I have these in my car with the Brey Krause R-1155 harness bar and use them with my HANS devices, both driver and passenger. Yes, I'd rather have the full (NHRA) certified 12-point cage that is in my street / strip drag Firebird. If I end up buying a ZL1 1LE to go along with my SS 1LE late in the year, one of these, probably the SS 1LE, will get caged with two full containment seats, a fire suppression system (in car, underhood, and underneath like my Firebird). |
02-14-2018, 03:55 PM | #27 |
I did not want to add a harness bar I just wanted the Quick Fit Pro set up. As stated in the other post if there is a BMW buckle that works in the Camaro it would just clip in and out for HPDE driving. Otherwise, I am going to buy this
https://www.schrothracing.com/produc...lye-belts#1575 Not as elegant as the Quick Fit option. |
02-16-2018, 06:09 AM | #28 |
Drives: 2017 ZL1 Join Date: Jul 2017
I am a FIRM believer that "to each is own", so I do not make too many comments about what others do, BUT
There is no way in hell I would want to be harnessed upright in a vehicle without a roll bar or cage. But i'm in a love affair with my head and don't want to loose it or it's option. |
