Old 05-30-2018, 12:35 PM   #1
Davis1LE
Drives: 2018 Camaro SS 1LE
Camaro SS 1LE skip shift?
Hello everyone I bought a 2018 SS 1LE a few days ago and I knew it had skip shift but sometimes when I drive it it feels like it wants to block out 2nd gear on me. I wasn’t sure if it was just me not being used to the clutch and the whole car yet but I googled and I didn’t see a definite answer but does the skip shift really block out 2nd gear?
Davis1LE is offline   Reply With Quote
Old 05-30-2018, 12:37 PM   #2
bmm2170
Yes, it does. A gate closes and the shifter will be directed to fourth gear. A message on the dash also comes up when this is activated.
bmm2170 is offline   Reply With Quote
Old 05-30-2018, 12:45 PM   #3
Davis1LE
Does the skip shifter eliminator void any warranties?
Old 05-30-2018, 12:54 PM   #4
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Sometimes I see the message, sometimes not, Still goes into 2nd gear. Weird
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs.
http://www.motorsportsne.com/
Vtor_ZL1 is offline   Reply With Quote
Old 05-30-2018, 12:59 PM   #5
Havoc54
Drives: 2018 SS 1LE
When I do get the message it only locks me out of 2nd gear about 30% of the time.
Havoc54 is offline   Reply With Quote
Old 05-30-2018, 01:07 PM   #6
Frankie18SS
Frankie18SS's Avatar
Drives: 18 Camaro 2SS, 07 Saturn Ion
It physically blocks out 2nd and 3rd as well. Had an eliminator on my 01 SS for 6 years and never had warranty issues. Not sure if they didn't notice or didn't care.
Ordered from Becky D __ 2018 2SS Silver Ice Redline 6MN, NPP, MRC, GM CAI
Frankie18SS is offline   Reply With Quote
Old 05-30-2018, 01:18 PM   #7
Bad Anvil Garage
Bad Anvil Garage's Avatar
Drives: 2000 GMPPSV SS & 2017 ILE SS
Depends on your rpm, etc. Hold first slightly longer to skip the skip. Most of the time I never know it's there because I don't drive like a granny.
Bad Anvil Garage is offline   Reply With Quote
Old 05-30-2018, 01:18 PM   #8
bmm2170
It does not block you from going into 3rd. When I feel it going into 2nd, I push up into third.
The message on the dash stays on too long. Once you reach a certain speed, the gate opens but the message remains.
Old 05-30-2018, 01:26 PM   #9
Hyper-1le
Drives: 2018 SS 1LE
It only kicks in for a specific throttle input range, for a specific speed range. If I happen to get the message, I'll usually either hold first gear for a few extra MPH or apply just a hair more throttle and the message goes away.
2018 SS 1LE - Hyper Blue
Hyper-1le is offline   Reply With Quote
Old 05-30-2018, 01:26 PM   #10
Frankie18SS
That's interesting. I know my old T-56 would block 3rd. I thought I'd be slick and shift from 1st right into 3rd, it would have none of it.
Old 05-30-2018, 01:30 PM   #11
Frankie18SS
I think that was my problem. It usually didn't come on and I'd forget about it. The 1 time every 2 weeks it did happen, it surprised me.
Old 05-30-2018, 05:36 PM   #12
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
It does not block 3rd. I thought about the eliminator, but have learned how to get around it.
torqueaddict is offline   Reply With Quote
Old 05-31-2018, 12:52 PM   #13
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
As mentioned it's a pretty tight window for it to actuate. I'd guess that 95% of us drive the car in a way that it never presents an issue. On times when it actually kicks in, I just shift to 3rd.
I hope the 6th gen Camaro has a melodious horn trumpet. I'll tootel it at the ladies, yelling out "Hi hi." - RenegadeXR
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 05-31-2018, 12:55 PM   #14
guitarman8373
guitarman8373's Avatar
Drives: 2016 2SS Camaro fully loaded.
SHIFT TO 3RD! Much less of a jerk than 4th is. On the plus side ... it saved us a grand or so on paying the gas guzzler tax.
I assume the the Zl1 doesn't have this feature though?
guitarman8373 is offline   Reply With Quote
