BeckyD @ James Martin Chevy
Old 01-23-2024, 01:39 PM   #1
Kelevra
Drives: Chevrolet Camaro
What mods should I do to close this gap?
Hello everyone I'm new to the forums!
I own a 2016 2.0 Camaro which currently I'm just running it with a K&N Cold air intake and a muffler delete, next mods I'm planning to do are downpipe and a tune but I was wondering, are those enough to close this gap? What else do you recommend to add?
Thanks!
https://youtu.be/PcqdSA2CC6c?si=jvEvmFULO_xILW3D
Kelevra is offline   Reply With Quote
Old 01-23-2024, 06:54 PM   #2
Davescamaro
Drives: Chevy camaro
Hey, I can barely stay with a mustang 5.0 myself, but probably a lot more than a dp and tune. I'm running FBO and tune. Don't know the exact numbers I'm pushing but probably low 300s would be a good guess. I would strongly recommend a rebuild of the block with stronger pistons and connecting rods. Then bigger injectors (Nostrom) and then a bigger turbo.
There are some good people in here that know their stuff and have literally everything that the LTG can be put in. It's not a V8 but it holds it own for a decent little engine. Not a HP heavy one though.
2019 Camaro 1 LT 2.0 Riverside Blue Metallic, ZZP strut bar, K&N intake, ZZP catted DP, MRT axle back, Injen IC piping, Trifecta Elite tune, zzp heat shield, turbosmart diverter valve.
Knockoff zl1 sideskirts, gm front chin spoiler, 1le blade spoiler, diode sides, 20" staggered Asanti black labels, azenis 510 245/40/20 fronts, nitto 555 g2s 275/35/20 rears.
Davescamaro is offline   Reply With Quote
Old 01-29-2024, 05:16 AM   #3
Davescamaro
If you wanted to see my bolt ons and what it sounds like you can watch a quick vid on it. Nothing fantastic, but you can see I've done quite a few bolt ons. Still have room for improvement.
https://youtube.com/shorts/jtoi3jKND...g9HaFtcMbwuMHQ
