Old 09-11-2018, 07:06 PM   #1
jvillareal1978
Drives: 2017 Camrao 2LT RS
Limited Slip
Is there a way to tell if our cars have a limited slip without doing a 1 wheel peel test? I dont even know if that was an option for us.
jvillareal1978 is offline   Reply With Quote
Old 09-11-2018, 07:23 PM   #2
Johnny2343
Drives: 16 1SS 6mn npp
If it’s a manual it has if it auto it doesn’t.
Johnny2343 is offline   Reply With Quote
Old 09-11-2018, 07:25 PM   #3
jvillareal1978
Does the auto have a different rear diff? If so is there an after market one that anyone suggests?
Old 09-11-2018, 09:27 PM   #4
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Autos have an Open Differential you cam convert it to a limited slip differential by ising the parts from i believe the V6 LGX if I'm not mistaken. I know Jason@JacFab did the swap.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile
Evil-Bee-NH is offline   Reply With Quote
Old 09-12-2018, 09:41 AM   #5
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
You can use the differential and axles from a 2.0 with a manual transmission, or LGX car with a manual transmission easily, and fairly cheap. Can't swap the differential without changing the axles also.
At least as far as I'm aware, no one makes an limited slip unit that will go into the stock 2.0/3.6 auto differential, and no one makes aftermarket gears for them.
Jason@JacFab is offline   Reply With Quote
Old 09-12-2018, 01:45 PM   #6
b0bsaget007
b0bsaget007's Avatar
Drives: 2016 2LT RS Blue Velvet
Originally Posted by Start The Machine View Post
DSG turbo farts. It's fuel igniting in the exaust.
Wrong thread
PC: i5-6600; RX 480 4GB; 16GB DDR4; Samsung 950 PRO 512GB SSD
Car: 2016 Camaro 2LT RS 2.0T 6M Blue Velvet Metallic | ZZP Hi-Flow Catted Downpipe | Injen EVO7300 Cold Air Intake
b0bsaget007 is offline   Reply With Quote
Old 09-12-2018, 02:11 PM   #7
Gutling
Drives: 2017 Chevrolet Camaro 2.0 LT
Would swapping the diff from an auto to a manual do anything with the shifting/spedometer being diff gears?
Gutling is offline   Reply With Quote
Old 09-13-2018, 12:54 AM   #8
b0bsaget007
The diff ratio is the same with either transmission (3.27), so that's a non-issue.
Old 09-13-2018, 09:25 AM   #9
2.0t_godfather
Drives: 2016 Camaro 2.0t
Do the swap. The open diff in the auto unit is a completely different carrier. It is very weak looking. The housing for the LSD diff is the same from all the cars to the SS. Much stronger unit.
2.0t_godfather is offline   Reply With Quote
Old 09-13-2018, 10:59 AM   #10
jvillareal1978
Sounds like we got the shaft with the auto. I decided to get the auto because in the press I hear that autos are actually faster than the manuals these days. Do the v6 with autos have a LS or they open as well?
Old 09-13-2018, 11:05 AM   #11
Jason@JacFab
v6 auto also has open diff. It's been that way since 2010. Gm trying to cut costs I guess?
Old 09-13-2018, 11:22 AM   #12
2.0t_godfather
The autos are faster. Spend the 1500 and move on.
Old 09-13-2018, 12:11 PM   #13
Gutling
Oh wow thanks, past vehicles i have always seen the manual/auto cars be different so just assumed would be off.
Old 09-13-2018, 12:59 PM   #14
2.0t_godfather
They are the same in the 2.0 cars. You jump to a different engine and things start to change.
