BeckyD @ James Martin Chevy
Old 04-03-2017, 10:04 AM   #1
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Diff swap! (Installing an LSD manual trans differential into an Auto trans car)
Well after several months of searching, I finally found myself a limited slip differential out of a manual transmission 2.0 car. Normally ~$1500-$1900 for just the diff and ~$400-600 for the axles at the dealership, I'm too cheap for that. I managed to score the differential w/ 12k miles on it and both axles for $595 shipped to my door.
Near as I can tell, GM make it easy for the 6th gen guys to do this swap. It requires less parts ($$) than the 5th gen v6 guys needed to swap out. As far as I can tell at this point based on diagrams and part numbers, the only things that are needed for certain is the differential, and the axles. I MAY (or may not) end up needing the manual transmission driveshaft, or maybe just the back half of it, but at this point, I won't be certain until I get the car ripped apart.
Jason@JacFab is offline   Reply With Quote
Old 04-03-2017, 10:33 AM   #2
tsanchez18
Software Architect
tsanchez18's Avatar
Drives: 2017 Camaro 2.0L Turbo
Current: '17 2.0T 1LT Hyperblue Metallic
Past: '09 Corolla (hell of an upgrade, huh?)
Mods: Mishimoto Catch-can, Mishimoto CAI
Tell me, ever danced with the devil in the pale moonlight?
tsanchez18 is offline   Reply With Quote
Old 04-04-2017, 06:21 AM   #3
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
If you have a line on a cheap M6 driveshaft and axles I'm in the hunt... Need them for the driveshaft shop...
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed
Corner carver is offline   Reply With Quote
Old 04-04-2017, 08:32 AM   #4
Nate...
Nate...'s Avatar
Drives: 2016 Camaro LTG
This is great! How did you get them? Wrecked car?
2016 LTG Camaro in Hyper Blue with MRT V3 Catback and Brembo SS Brakes.
Nate... is offline   Reply With Quote
Old 04-04-2017, 09:47 AM   #5
Jason@JacFab
Sorry, it's all going in my car lol I'll have some automatic stuff in the near future, but I don't think that will do you much good.
Yes, a car that was hit in the front end. It took some work. I found that while it should be easy for them, with computer technology and what not, a lot of the wrecking yards I called don't know what they have... I ended up having to get vin numbers for a bunch of cars, then calling the dealer parts center to have them check each vin to tell me which engine and transmission the cars had. I spent probably 2-3 hours making phone calls and literally only found ONE manual transmission 2.0/3.6 car (they share the same differential) in everything I found listed online in the country.
Old 04-04-2017, 11:40 AM   #6
Nate...
Nate...'s Avatar
Man! What a process. I'm not shocked though. Most of those places are less than optimally organized.
Old 04-04-2017, 01:21 PM   #7
Corner carver
Old 04-05-2017, 04:14 PM   #8
Jason@JacFab
Got tracking info, I wonder if they decided to give me some other random parts that may have been attached... The FedEx tracking page says the box weighs 142 lbs =:O
Hope it's packed well!
Old 04-05-2017, 05:49 PM   #9
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
2017 1LT RS I4 A8 BLACK ON BLACK
Kindness and compassion #OthersFirst
Michigan1LTRS is offline   Reply With Quote
Old 04-10-2017, 05:33 PM   #10
Jason@JacFab
Parts showed up!
Old 04-10-2017, 05:40 PM   #11
Corner carver
Parts showed up!
Rear diff looks heavy...
So we have different diameter axles same as the V8, wonder why? Engineered fail point?
Old 04-10-2017, 06:44 PM   #12
RedonBlackRS
Drives: 1LT RS 2.0T 8A HD
The longer one is thinner, so their masses stay roughly the same. The idea is to reduce wheelhop. At least that's how it was explained on the CTS-V.
RedonBlackRS is offline   Reply With Quote
Old 04-10-2017, 07:01 PM   #13
Corner carver
Reduce wheel hop with just equalizing the weight?
Old 04-10-2017, 07:50 PM   #14
Jason@JacFab
Right. I seem to recall reading something that said if they were the same diameter once the wheel hop starts it will start it amplify itself, the different diameters will fight this.
The big axle feels like it's probably hollow.
