TireRack
Old 06-17-2014, 09:58 AM   #1
Visago
Visago's Avatar
Drives: 2010 Camaro 2SS/RS
Anyone have this overheating issue...
When I'm in traffic my car will overheat excessively at times. Doesn't happen all the time but only sometimes when I'm in stop and go traffic. It's pretty weird too because it's acted up on days where it wasn't even that hot out. Last time it happened the temp gauge pretty much damn near pinned all the way to the right and the car told me to shut it down. I pulled off in a parking lot and let it cool down for a few, started it back up, and it was doing it again. This time I cranked the heater and that brought it back to normal and then I was out of traffic and it was fine. Wondering if my thermostat is getting stuck. The fans are coming on so that's not the issue. Anyone else have this problem? Maybe I need to put a lower degree thermostat in the car being that I live in Texas and it doesn't really get all that cold out here. Any suggestions?
Visago is offline   Reply With Quote
Old 06-17-2014, 10:07 AM   #2
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
Make sure it's full of coolant.
MMC is offline   Reply With Quote
Old 06-17-2014, 11:44 AM   #3
Avenging Orange
Avenging Orange's Avatar
The most common cause.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 06-17-2014, 02:38 PM   #4
maddoggyusa
maddoggyusa's Avatar
Drives: 2013 Camaro Dusk 2SS/6
if it's stop and go traffic, I'd check if the electric fan is turning on/off
Like other said, check coolant level. A small leak can be very hard to find. you could do a pressure check. If that's good, then I'd be thinking thermostat.
maddoggyusa is offline   Reply With Quote
Old 06-18-2014, 09:13 PM   #5
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
I doubt it's the thermostat. Check your coolant level first. If that's fine, I'd look at the cooling fans and the circuit that controls them.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 06-19-2014, 07:48 PM   #6
Flatwood22
Drives: 2LT
I'm having similar problems with my 2LT. My car is currently with the dealership, I will update soon.
Flatwood22 is offline   Reply With Quote
Old 06-20-2014, 04:38 PM   #7
Flatwood22
Drives: 2LT
Alright, just got my car back from the dealer and just like everyone was saying, the coolant was low. The problems seems to be solved now. Hope this helps. Good luck!
