09-29-2014, 09:43 PM | #99 | |
Drives: 2010 Camaro 2SS/RS 6MT Join Date: Apr 2010
"It's a device that plugs to your Gas Pedal harness and has a wired remote that allows you to fine tune the way your Throttle responds." PER THE VENDOR'S OWN WORDS it just adjusts the sensitivity. Having a built in delay would serve no purpose and there is no such function of the gas pedal sensor on the 5th gen. Even if it did have anything like that, a device like this that is installed INLINE LOL would not obviate that function. You would need entirely new pedal sensors. If you can point me to a delay in the factory GM sensor in FACT I'll retract everything I said. Don't worry I'll wait LOL because you aint finding that anywhere. |
09-29-2014, 09:44 PM | #100 |
Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
Yes, there seems to be a builtin delay on the throttle peddle signal to the ecm. The controller eliminates the lag significantly.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
09-29-2014, 09:44 PM | #101 |
Drives: 2010 Chevy Camaro 2LT / RS / Auto Join Date: Jan 2010
We can keep arguing for days and neither one will be able to prove if he's right or wrong.
Have you ever tried any of the available Electronic Throttle Controllers on the market before ? or maybe you've tried one that simply amplified the Voltage signal and nothing else. You're quoting what others have said on other forums. I will not reveal any details or try to convince you that our new Controller works or not because You already have your own personal opinion about this Controllers and I respect that. You're saying that "Poor response is due to worn out engine components" so how can you explain the big difference felt on a brand new 2014 L99 engine without any "Worn out engine components" ? "Thus the only way to increase throttle RESPONSE is to modify ENGINE components" WRONG ! On a Drive-by-Wire system, you can do that many different ways! A simple Tune or modification on the electronics responsible for sending the Gas pedal signal to the Throttle Body sensor and that's simply what we did. The new Corvette C7 has something very similar that controls not only the Throttle response but also the suspension.... It's called: "Driver Mode Selector" Do some research. The Ferrari has built also their own "Throttle Controller" with a switch right on their Steering wheel ! The McLaren P1 : Different Modes selector on the center of its dash. Many other Sports cars manufacturers have implemented these "Tricks or we should say SCAMS" to fool their buyers. Should we call all these Car Manufacturers: Scammers ! Are there customers happy with the results ? This is what counts ! |
09-29-2014, 09:48 PM | #102 | |
Drives: Really Slow Join Date: Apr 2010
Throttle response:
http://en.wikipedia.org/wiki/Throttle_response Quote:
09-29-2014, 09:53 PM | #103 | |
So you're telling me, by putting wires in between that, that this imaginary built in delay is now gone? Based off fundamental electronic construction that is impossible. To delay a signal you would need a type of controller and to bypass that type of controller you would completely need to eliminate that device from your inline circuit. This device is just attached onto the existing wire structure. Put more simply, if there was a delay, you would be removing something and putting this controller in place of that. Instead you are just adding this piece in and taking nothing off. Hopefully put in these simple terms it makes sense. There is NOOO delay built in lol |
09-29-2014, 09:58 PM | #104 |
'It's an experiment'
Can we just move on? I see your point. How about DarkneSS you start a discussion thread and lets discuss this there. Each side, if they choose, can submit facts/opinions as needed...
Thanks... |
09-29-2014, 09:58 PM | #105 | |
So I'll ask the questions you do not want to answer since you want to play it that way. What does your device do to the signal being sent out of the pedal sensor to the ECM? How does it modify that signal? Does your device reduce the amount of time the ECM takes to send a signal to the throttle body sensor? Does your device reduce the amount of time it takes for the pedal sensor to send a signal to the ECM? I already know the answers but this should make it more clear to your buyers on what this booster actually does. |
09-29-2014, 09:59 PM | #106 |
Wow, ever heard of lead lag compensators ? Basic electronics. Have you opened the side of the pedal ? There is circuitry in there. Simple resistive capitative circuit will cause a delay.
The could be done to simply trim sensitivity to make car more drivable to average person.
09-29-2014, 10:03 PM | #107 | |
09-29-2014, 10:04 PM | #108 |
Ride On!!!!
Don't see any numbers down the track.
09-29-2014, 10:06 PM | #109 |
Thanks to jacfab here is the pedal module. Looks a lot like a resistive and capacitive circuit. Now why would they do that ?????
09-29-2014, 10:08 PM | #110 | |
So you think the delay happens in the pedal sensor. Okay. So that means after the pedal is pressed a delayed signal is sent out of the pedal. So then it would go into this device. By your own logic, by the time the signal leaves the pedal it is already delayed. If the signal has already been delayed, then how could this thing undelay it? A similar question would be if a train leaves a station late, how can we make it leave on time after it has already left late? Makes no sense right? In exactly the same way as your proposition does. |
09-29-2014, 10:13 PM | #111 |
So, for those of you who have it, what settings are you using? I found for my L99 with 3.91 gears and 400 RWHP, 6 is pretty good for me. > than that and its too sensitive -- will 'leap out' with very little press of the throttle -- like a bronco busting out of a gate...
09-29-2014, 10:13 PM | #112 | |
Drives: 2012 SIM 2LT/1970 Camaro Join Date: Nov 2012
I could STOMP my gas pedal before and get virtually no wheelspin. If I nail the gas with this device installed and set to 9 (or even 5), I get significant wheelspin. It's doing more than just opening the throttle plate further with less pedal travel. But believe what you want. How many people in this thread who've actually received this device are expressing disappointment? I guess we're all just fools, huh?
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting |
