Old 04-30-2021, 04:17 AM   #1
Gneppo
Drives: Chevy Camaro and Corvette C6
Code P2097 and downpipe
I have recently changed the downpipe with the catted ZZPerformance.
Everything went smooth for a couple of weeks but yesterday I got a P2097 code. I have checked all bolts and connections and all looks OK. I cannot see any sign of leaks. Any suggestions on what else to check?
Gneppo is offline   Reply With Quote
Old 04-30-2021, 11:09 AM   #2
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
There are dozens of harmless emission codes aftermarket downpipes will trigger. You need some sort of software to permanently turn off the codes.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 04-30-2021, 06:45 PM   #3
Davescamaro
Drives: Chevy camaro
Start the machine is correct. The b1s2 o2 sensor will read more flow than the oem and it can trigger multiple codes. Did you install the extended the downpipe come with it? I kept throwing a p013f due to it and wiped it out on a tune.
2019 Camaro 1 LT 2.0 Riverside Blue Metallic, ZZP strut bar, K&N intake, ZZP catted DP, MRT axle back, Injen IC piping, Trifecta Elite tune, zzp heat shield, turbosmart diverter valve.
Knockoff zl1 sideskirts, gm front chin spoiler, 1le blade spoiler, diode sides, 20" staggered Asanti black labels, azenis 510 245/40/20 fronts, nitto 555 g2s 275/35/20 rears.
Davescamaro is offline   Reply With Quote
Old 05-01-2021, 02:39 AM   #4
Gneppo
Yes, the extension is installed. I'll have the car tuned in the near future and I want to be sure these codes are somewhat "normal" after the downpipe change
Old 05-01-2021, 10:09 PM   #5
Davescamaro
I don't know for sure, but it seems that every little performance part you throw into it, the PCM does not like it at all and throw some type of code. I know adding stuff for more air and fuel will change the way your b1s1 tells the pcm to either toggle lean or rich.
A tune will be able to disable codes and balance out what you put on it or replaced with better.
Old 06-02-2023, 07:43 PM   #6
Ruthless Camaro
Drives: Chevrolet Camaro 2SS
I just got Stainless Works axel back, and a week later I got P2097, but a month ago i did get a catback but didn’t like it, so that why I went to axel back, so therefore I had to get the OEM exhaust welded back on, i don’t know if maybe they didn’t weld it back on correctly
So that’s what’s causing the code
Ruthless Camaro is offline   Reply With Quote
Old 06-04-2023, 02:37 PM   #7
Davescamaro
I get that code from time to time. It is stating b1 s2 reading too lean. I'll get it if I stay in gear and let the rpms come down. You will need a tune to fix that. I just haven't gotten the chance to permanently erase it.
