TireRack
Old 10-08-2014, 11:19 AM   #1
CamaroSSkid
CamaroSSkid's Avatar
Drives: 2014 Ashen Gray 1SS/RS M6
skipping shifts in my standard 2014 1SS Camaro
Hello all,
I am new here. I recently traded my 2010 Camaro 2LT for a 2014 1SS, I also made the switch from an automatic to a standard. The only problem that I have with the car is that I hate that sometimes it wants me to shift from 1st gear into 4th gear. I understand that it is trying to help me save fuel but I bought a v8 so I am not as concerned with fuel usage. I guess what I am wondering is if there is a way that I can turn off that feature. I looked at the manual and it says to just do the shift to avoid damaging transmission. Typically I just get on the gas a little harder to get above 2000 rpm and that's how I avoid it. Is there a chip I can buy or a way to bypass the annoying 1st to 4th shift? sorry if this post has been done before, I couldn't find it :/ thanks for the help
CamaroSSkid is offline   Reply With Quote
Old 10-08-2014, 11:26 AM   #2
benji276289
benji276289's Avatar
Drives: 2021 Camaro 2SS1LE, 6 spd.man., Ora
Send a message via Skype™ to benji276289
I agree. I don't care for the feature. The way it comes up, it almost invites you to damage your transmission. Maybe if it showed on the HUD, you would be more aware of it because I am not always looking at the DIC especially when I am starting up from a light. My immediate gut reaction is to force it into second until I realize a moment too late that I have to go straight to 4th. I wish there was a simple way to disengage it but sadly I don't think there is.
benji276289 is offline   Reply With Quote
Old 10-08-2014, 11:31 AM   #3
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
Easy and cheap. Search for skip-shift eliminator. I know most of the vendors on here sell them. It's a $25 fix.
chef-beavis is offline   Reply With Quote
Old 10-08-2014, 11:32 AM   #4
NYYFan325
Drives: 2010 Camaro 2SS/RS
Google skip shift eliminator... Very simple fix
NYYFan325 is offline   Reply With Quote
Old 10-08-2014, 11:33 AM   #5
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
Skip Shift eliminator. they are cheap and it takes less than 5 minutes to put it in. You still see the message pop up but it does not force the shift.
http://www.phastekperformance.com/20...eliminator.htm
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers
AGM 1LE is offline   Reply With Quote
Old 10-08-2014, 11:33 AM   #6
Enduring
Enduring's Avatar
Drives: 2013 2SS/RS M6
You can buy a simple harness that will remove the skip shift feature. It's called a skip shift eliminator and gen5diy, Phastek and Summit Racing all sell them. They are pretty cheap at only around $20.
I just adjusted my driving habits and now I only see the skip shift notification once every few weeks.
Enduring is offline   Reply With Quote
Old 10-08-2014, 11:36 AM   #7
Taco Time
Taco Time's Avatar
Drives: 2014 1SS
If you mod your car when you get it tuned they will tune that out.
Otherwise, it only engages the skip shift when you're accelerating slowly. So if you are just cruising then just put it in 3rd instead of 4th. Or just accelerate faster.
Taco Time is offline   Reply With Quote
Old 10-08-2014, 11:36 AM   #8
CamaroSSkid
Thank you!
Ordering one now thanks everyone!!!
Old 10-08-2014, 03:12 PM   #9
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Don't be fooled by the 5 minute install. It takes 5 minutes to install it after you spend 15 minutes dragging out floor jacks and jack stands and getting the car in the air, lol. Also, the solenoid is almost on top of the transmission. There is also a reverse lockout solenoid lower down on the side. Make sure you don't install in that location by mistake. It also helps if you have hands like the guy in the Burger King commercial a while back. It's pretty tight in there. It is really easy and I installed one in my 2010 SS, then later had it tuned out anyway. I had the dealer install one in the ZL1 when I went in for my first oil change.
Old 10-08-2014, 03:21 PM   #10
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
If you plan on going for a tune, just have your tuner take it out.
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 10-08-2014, 03:29 PM   #11
skipinminn
Chiquita
Took Mine to the dealers they put it in during an Oil Change didn't charge me a dime
Old 10-08-2014, 06:59 PM   #12
satxrider
Bad 45th
satxrider's Avatar
Drives: 2012 45th Anniversay Edition SS
I simply drove up to an oil change service bay and offered $10 to let me install the plug myself and drove off. 5 minute install but 15 minutes of talking about cars
- Carl
2012 45th Anniversary SS - LS3
Magnuson TVS 2300 Supercharger / Alky Meth Injection / Lingenfelter GT12 Cam / Kooks LT Headers, 3 inch exhaust & QTP electric cut outs / Monster LT1-S Twin Disc Clutch / MGW flat blade short throw shifter / Haltech CAI / VMax Throttle Body / DSS Stage 3 axles/ BMR Trailing Arms, Toe Rods, Suspension Bushing and 1" lowering springs / Taylor 8MM Plug Wires / Tuned by Henderson Performance Technologies / EBC dimpled and sloted rotors / G2 Painted Calipers / GM Tower Strut Brace / ZL1 Factory Rep Wheels
satxrider is offline   Reply With Quote
Old 10-08-2014, 08:07 PM   #13
CamaroJoe96
CamaroJoe96's Avatar
Drives: 2013 Full Bolt on LFX M6
Before you curse GM, think of how genius the skip shift is. It allows people to get a powerful v8 car without getting hit on gas guzzlers tax, and they purposely made it easy to disable if wanted. Gotta give those engineers credit
CamaroJoe96 is offline   Reply With Quote
Old 10-08-2014, 08:26 PM   #14
jrhagen
Drives: Camaro
More right foot pressure, problem solved.
jrhagen is offline   Reply With Quote
