Vararam
Old 03-15-2014, 01:14 PM   #1
HypnotiqSS
HypnotiqSS's Avatar
Drives: 2010 camaro 1ss
Catch can installed, is this normal?
I installed the catch can last night and this morning I drove to cars and coffee, checked my can and saw what I think is a lot of oil for only driving 35 miles. I took the picture when I got home and the total miles driven was about 75-80. is this normal or did I mess up the install?
Flowmaster AT catback, Roto-Fab cai, VMAX ported TB, MGW Shifter, Elite Catch Can.
HypnotiqSS is offline   Reply With Quote
Old 03-15-2014, 02:17 PM   #2
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Were you driving like you stole it ? Were you reveing past 5500 rpm ? If not that should not be in only 75 miles .That looks like a nice neat install ,and looks right to me .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 03-15-2014, 02:24 PM   #3
HypnotiqSS
HypnotiqSS's Avatar
I may have got on it a little, but not excessively.
Old 03-15-2014, 02:32 PM   #4
B-_-RAD
Drives: ...
That seems pretty excessive. I've had mine on for a couple weeks and only got a few drips out of it
B-_-RAD is offline   Reply With Quote
Old 03-15-2014, 02:33 PM   #5
B-_-RAD
Drives: ...
Valley cover might be leaking
Old 03-15-2014, 02:40 PM   #6
HypnotiqSS
HypnotiqSS's Avatar
should I be concerned? or wait a week to see how much oil I collect?
Old 03-15-2014, 03:02 PM   #7
1LE801
"Lohla"
1LE801's Avatar
Drives: 2016 1SS A8 :"Lohla"
Not sure how much is "normal" but I've gone almost 1000 miles since my install and I have just a tad more than that.
OG Trans and Diff but all else is upgraded. Twins bring wins ;-)
1LE801 is offline   Reply With Quote
Old 03-15-2014, 04:09 PM   #8
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M
Its hard to tell from the pictures, but how far down is the catchcan mounted??
The can is supposed to be mounted up higher then the ports on the Valvecover and/or valleycover. If the can and its associated 'feed' line is mounted down lower then where the ports are, you're going to get an excessive amount of oil in the can.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq
3rdgen3 is offline   Reply With Quote
Old 03-15-2014, 04:21 PM   #9
HypnotiqSS
HypnotiqSS's Avatar
the can is mounted as high up as it can be(if that's what your referring to)
also it has 24k miles, 2010 ls3, if any of that is relevant
Old 03-15-2014, 04:32 PM   #10
3rdgen3
10-bolt Destroyer
3rdgen3's Avatar
No, your can is NOT mounted up as high as it can, lol. Maybe with what you have, but the placement matters.
Bottom line is, if your catch can is sitting down low/lower then the PCV and Valley cover ports where the catch can draws the oil from, then you will prematurely fill the can with more oil then whats normal, as some of that would drain back into the motor instead of into the can.
Get it?
I see the mounting tab you have on your block beside the tensioner, but like i said, its hard to tell in the pic how high UP the can is sitting.
Old 03-15-2014, 04:36 PM   #11
GONIF
GONIF's Avatar
Bottom line is, if your catch can is sitting down low/lower then the PCV and Valve cover ports where the catch can draws the oil from, then you will prematurely fill the can with more oil then whats normal, as some of that would drain back into the motor instead of into the can.
Get it?
I think you are right ,missed it in the picture . Can't hurt to mount it higher .
Old 03-15-2014, 04:40 PM   #12
HypnotiqSS
HypnotiqSS's Avatar
how do I mount higher with the parts supplied? thanks for the advice and info guys
Old 03-15-2014, 04:44 PM   #13
GONIF
GONIF's Avatar
if you want to mount it higher on the same tab , make a extension out of a piece of mtl .
Old 03-15-2014, 04:52 PM   #14
HypnotiqSS
HypnotiqSS's Avatar
I understand what you guys are saying, but if its mounted as high as it can with the parts supplied, why would elite not extend the mounting bracket to ensure this problem wouldn't happen? What kind of sense does it make that the buyer has to fab up an extension piece to make it function properly?
