dave@hennessey
Old 02-10-2024, 01:55 PM   #1
s/c ss
s/c ss's Avatar
Drives: 13 ZL1, 10 Silverado LTZ, Chopper
M6 transmission fluid
How many pints of transmission fluid will I need to remove old fluid and replace with new?
Thanks in advance.
s/c ss is offline   Reply With Quote
Old 02-10-2024, 03:34 PM   #2
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Assuming your a ZL1 with the Tremec, transmission capacity only is 3.65 quarts, not pints.
This does not include the fluid in the cooler(s)
Total capacity for ZL1 is 4.65 quarts with cooler
Total capacity for Z28 is 4.54 quarts with cooler
Base model is 4.22 Quarts with cooler
When filled, fluid level should be at the bottom of the fluid check plug hole.
Trans fluid p/n 88861800 for US (88861801 for Canada)
Drain and fill plug torque is 20 lb/lb (27Nm)
FasNuf is offline   Reply With Quote
