Old 07-14-2019, 11:32 AM   #1
lDejavul
lDejavul's Avatar
Drives: Camaro SS
Under hood battery posts
So I was doing an installation and accidentally grounded myself out on the 6 post. It doesnt have 12v power anymore and I'm trying to figure out why. Is there a fuse tied to this post? I thought they were all just direct from the battery but I guess not.
Adrenaline Red
20" 5 Spoke Black
Black Side Spear
Dual Mode Exhaust
MRC
Splash Guards
1G1FG1R74G0124089
lDejavul is offline   Reply With Quote
Old 07-14-2019, 11:49 AM   #2
RobertAvitia
BYND GARAGE
RobertAvitia's Avatar
Drives: 17' 1LT Turbo
I believe there’s power to all those
RobertAvitia is offline   Reply With Quote
Old 07-14-2019, 12:50 PM   #3
lDejavul
lDejavul's Avatar
Drives: Camaro SS
Figured it out. Just in case anyone does like me in the future the entire block is a fuse. So note to future self. Its ALWAYS easier to just remove the negative battery terminal. Even if you are just "making a quick connection". What should have taken me 10 minutes has turned into quite an affair.
Adrenaline Red
20" 5 Spoke Black
Black Side Spear
Dual Mode Exhaust
MRC
Splash Guards
1G1FG1R74G0124089
Old 07-14-2019, 01:00 PM   #4
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Good info, thanks for sharing. Too bad you had to find out the hard way! Hopefully your info will save someone else some aggravation.
Old 07-14-2019, 07:12 PM   #5
Paintslinger16
Two Lane Blacktop
Paintslinger16's Avatar
Drives: '18 Camaro 2SS
Thanks!
Paintslinger16 is offline   Reply With Quote
Old 07-15-2019, 08:05 AM   #6
overdriv
overdriv's Avatar
Drives: 1969 Chevelle SS 2019 2SS Camaro
Please share how you fix your problem
overdriv is offline   Reply With Quote
Old 07-15-2019, 08:21 AM   #7
red_johnny
red_johnny's Avatar
Drives: 2016 Gray 2SS M6
Great info. Guess we need to be careful if we are adding anything from that point.
red_johnny is offline   Reply With Quote
Old 07-15-2019, 08:45 AM   #8
Silverado57
Silverado57's Avatar
Drives: 2017 Camaro SS
Great post and cautionary tale. Thanks.
Kevin
Luceo Non Uro
Silverado57 is offline   Reply With Quote
Old 07-16-2019, 03:29 PM   #9
DIYguy
DIYguy's Avatar
Drives: 2017 Camaro 1LT
Smile
I second that this is great information (or 3rd or 4th it).
Good to know and something to be careful of.
I added a supercapacitor bank to mine a while back, connecting it from the main feed terminal (B+, second in from the end) to ground.
It has an integral 175 ampere fuse but if it hadn't had one it would have been better to connect it to the 200A terminal I think.
Out of idle curiosity I tried to locate a direct replacement for that junction bar but couldn't.
Everywhere I looked all they sell is the entire fuse box as an assembly.
However if I may offer a suggestion- For about 10% of the price of a new fuse box add an AMG-100 (bolt-on) fuse to that post and a short copper strap jumper over to the main B+ terminal.
Other manufacturers make them too (like the Littelfuse 298 "Mega" or BF1 series fuses).
Stereo shops should carry them in stock for high power amplifier setups.
Gen6 Camaro LT (my daily driver), Cruze ECO (grocery getter), Chevy SS Pickup (wife's daily driver), Honda Shadow, Honda CBX
DIYguy is offline   Reply With Quote
Old 09-07-2020, 03:20 PM   #10
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
Wow I used one of those terminals for a battery maintainer. Had I known I could have done that I would have disconnected the negative cable. How much was that fuse block?
craigss50 is offline   Reply With Quote
Old 09-08-2020, 07:36 AM   #11
ember1205
Hot Camaro
ember1205's Avatar
Drives: '20 2SS Convertible 6MT
Not all model years are the same on this. My 2020 does not have constant power to those other terminals...
ember1205 is offline   Reply With Quote
Old 09-08-2020, 08:19 AM   #12
Magnum922
Magnum922's Avatar
Drives: 2017 Camaro 2SS, A8
How much is a new one? Is it just a dealer part?
Magnum922 is offline   Reply With Quote
Old 12-06-2023, 05:41 AM   #13
BarTek
BarTek's Avatar
Drives: Camaro HotWheels
Gentlemen, please let me know which pin the black cable should be attached to.
BarTek is offline   Reply With Quote
Old 12-06-2023, 06:35 AM   #14
BarTek
BarTek's Avatar
There is already a cable for 6 pin. This one is too short to get to pin 6. When I connected it to the red wire to pin 2, the starter turned. I haven't tried any others, I don't want to burn anything.
