04-19-2012, 09:32 PM | #1 |
Drives: 2014 Stingray Z51 Join Date: Oct 2011
Any body's battery getting hot?
Mines averaging 219 degress which on the dial is above half... anyone expieranceing the same... and btw the motor gets extremely hot and smells like something is buring at times?
Thanks
"What a coincidence, Drake returns and brings
brand new ZL1's with him...." - CAM....ZL1 |
04-19-2012, 09:36 PM | #2 |
Drives: Invalid Join Date: Aug 2010
Dunno about your battery? Are you reading that on the center console gague, the one above the vac/boost gague? Top right. The smell really didn't go away Til about 1300 miles and you can still smell it whenever you beat on it a little bit, still. Seems fairly normal though.
04-19-2012, 09:40 PM | #3 |
no im my diagnostic menu and sorry not battery the coolant! but everything under the hood is super hot!
04-19-2012, 09:43 PM | #4 |
My coolant temp usually averages between 192 and 200, but then again you're in the south and I'm up here in Michigan.
04-19-2012, 09:44 PM | #5 |
oh ok Im about to find out if this is normal! not complaining just want to ensure im not hurting my baby :/
04-19-2012, 09:55 PM | #6 |
Drives: '12 SIM ZL1, 1 of 49 Join Date: Sep 2011
Mine runs 190* to 198*. I haven't run it hard yet. Still doing the break-in, only 850 miles. No smells.
04-19-2012, 10:01 PM | #7 |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
I'd check to make sure that you have enough coolant. That seems to be a bit high for normal street driving
04-19-2012, 10:02 PM | #8 |
hmm I will check!
04-19-2012, 10:05 PM | #9 |
Drives: 2010 Camaro 2SS RS Join Date: Feb 2012
mine stays at 190 most of the time.
04-19-2012, 10:23 PM | #10 |
Drives: 2017 ZL1 Status "Thank You!" Join Date: Feb 2009
219 degrees for me. Coolant and oil at proper levels. But, wow, was the engine bay quite hot! My dipstick was so hot, you couldn't hold the little handle to pull it out (no pun intended)... the air filter box and air intake pipe and fusebox were all hot. Don't even ask me about the cross brace... all "ouch"... I think it's ok.
04-19-2012, 11:35 PM | #11 |
Drives: Getting 2010 Camaro Join Date: Jul 2008
engines tend to run a little "hotter" when new. As it breaks in it should cool down a little.......
04-19-2012, 11:45 PM | #12 |
Drives: 04 Silverado Join Date: Jun 2010
sounds about normal
04-20-2012, 07:15 AM | #13 |
Plays with Hot Wheels
Drives: '17 Jet Black ZL1 Join Date: Apr 2010
......seriously?
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette, '10 SS, '13 SS Hot Wheels
Current Cars: '17 ZL1(daily driver), '04 Trailblazer (rain & snow), '66 Corvette (restoring) Last edited by Ron66Vette&10SS; 04-20-2012 at 07:51 AM. |
04-20-2012, 07:35 AM | #14 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Superchargers add heat. Also heat is directly related to hp.
On the plus side, supercharged cars get cabin heat fast on a cold morning. I had a supercharged Grand Prix for a DD for a while. Greatest winter car, had heat going real quick. Just make sure the rad is full when cold, the surge tank is at the full cold level, and the supercharger coolant supply is full at the cap under the S/C cover. If all that is good, I wouldn't give it another thought. |
