Old 04-11-2017, 09:33 AM   #127
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
Originally Posted by Tonka1 View Post
Checking on availability on the custom snout for 102mm your making
Trying to get the prototype on the dyno this week or next before we go any further in the design phase so we don't waste too much time.
2012LS3VERT is offline   Reply With Quote
Old 04-17-2017, 12:31 AM   #128
tlamb2
WHPLSH
tlamb2's Avatar
Drives: 2010 SS Maggie,ARH,Meth,AFE Coilove
2010 ss ls3 Maggie 2300 with a 3.30 pulley stock belts, AR headers Bassani full 3in exhaust, Airaid CAI, Labonte Meth injection and a good tune by RPM motorsports in Santa Clarita CA the last dyno was 567hp 558tq. My question is how do I know if my pulley is slipping and what other bolt on parts should I use to pick up more power. any help would be appreciated
tlamb2 is offline   Reply With Quote
Old 04-17-2017, 04:40 PM   #129
Yezzir600
Drives: CGM 2SS/RS
Sorry to thread jack but since there are so many TVS owners on this one I need help...
Attempting to remove my rear cogs with the blower on... WTF! What a pain, is this even possible?
Has anyone done this?
Any tricks to access the bolts? Windshield cowl removal or special sprocket?
Yezzir600 is offline   Reply With Quote
Old 04-17-2017, 04:53 PM   #130
2012LS3VERT
Good cam in that motor is worth 60-70rwhp easy. If your belt is slipping, the tuner should have seen it on the dyno with either the MAP readings or if the dyno had a MAP sensor hookup to display directly on the dyno chart. They usually start slipping significantly with smaller than a 3.4 pulley and a 6 rib.
Old 04-17-2017, 04:56 PM   #131
2012LS3VERT
I have done them on the car, ALMOST impossible. i have several different ratchet wrenches I use to get to them. But now I can have the blower off almost more quickly than I can pull just the cogs. I just remove the intake bolts and move the blower forward a couple inches, don't even disconnect the coolant hoses. Did a car with an e85 sensor and it had enough slack in the fuel line that I didn't have to disconnect it either, just the air intake and belt.
Old 04-18-2017, 09:54 AM   #132
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
Chances are, it's slipping. I have a 3.4" Griptec pulley and super-tensioner, and it still slips above 6K RPMs. If you see a sudden drop in power on the dyno, that's a good sign it's slipping.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 04-18-2017, 07:43 PM   #133
RankSS
Drives: 2010 Camaro SS
Add a good blower cam and pull 650 RWHP. A super tensioner will help with belt slip. Try to stay 3.4 or larger on the pulley.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 04-18-2017, 11:52 PM   #134
2010SSRSM6
2010SSRSM6's Avatar
Drives: My wife crazy with my C5 usage.
How's the testing looking?
UNDER CONSTRUCTION......again......
2010SSRSM6 is offline   Reply With Quote
Old 04-19-2017, 09:08 PM   #135
2012LS3VERT
I have to contact the owner of the shop with the dyno. The shop is an independent local shop who just happened to have a fresh build maggie car that one of the employees own, but it is race season for them so they have to squeeze it in on a weekend for the back to back testing.
Old 04-19-2017, 09:10 PM   #136
2012LS3VERT
quite a bit of the time it is slipping at the crank pulley. That's why mine is set up like this:
Old 04-19-2017, 10:28 PM   #137
SannerRacing
SannerRacing's Avatar
Drives: 2010 1SS RS IOM
Just send one out here to Cali will test it!
Forged LS3 416ci, Maggie TVS2300 @ 13lbs boost, McCleod twin disc clutch, GForce 1320 nine-inch 389 gear ratio, Hurst line-lock, 750 whp 700 wtq
SannerRacing is offline   Reply With Quote
Old 04-20-2017, 08:18 AM   #138
2012LS3VERT
That is what I should have done!
Old 04-20-2017, 09:32 AM   #139
2010SSRSM6
2010SSRSM6's Avatar
Mine will be going on the dyno this week.....
Old 04-20-2017, 10:03 AM   #140
2012LS3VERT
Yeah, the only snout i have left is at the shop already, I couldnt go get it and have it to you this week. I sold the second prototype one to a forum member.
