View Poll Results: More rwhp
ZL1 40 59.70%
Z06 27 40.30%
Voters: 67. You may not vote on this poll
Old 06-06-2016, 10:49 PM   #1
fattyz28
fattyz28's Avatar
Drives: 20 2SS 1LE
Which will put more power to the ground?
Curious what you guys think.
fattyz28 is offline   Reply With Quote
Old 06-07-2016, 01:50 AM   #2
g3ngo
Drives: 2013 Audi TTRS, 2013 Ford Edge
Manual for manual, auto for auto, I think ZL1 because it will likely have been engineered with better cooling (don't want to repeat the Z06 issues).
g3ngo is offline   Reply With Quote
Old 06-07-2016, 07:49 AM   #3
mcsoul
Drives: Want a gen 6
The ZL1 has a bigger front intake area (grill) so it will breath better.
mcsoul is offline   Reply With Quote
Old 06-07-2016, 08:27 AM   #4
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
SS has been reported to put power down better than the Stingray. Not by much...but at least a little...I imagine the same will be true of the ZL1.
Old 06-07-2016, 12:08 PM   #5
Denis
Denis's Avatar
Drives: 2010 SS
if its GM advertising, id say the Z06. Real world? probably will depend on the day and the dyno.
Denis is offline   Reply With Quote
Old 06-07-2016, 02:25 PM   #6
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
Please clarify power to the ground. Dyno? 1/4 time? Cornering?
2cnd chance is offline   Reply With Quote
Old 06-07-2016, 06:37 PM   #7
396ssrat
Drives: 66 Chevelle SS
How would one know without having the spec's?
396ssrat is offline   Reply With Quote
Old 06-07-2016, 06:45 PM   #8
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
GM doesn't advertise power at the wheel
Only a dyno actually measures how much power is being put to the ground.
The OP wants to know what we think will happen ... ie, our guesses and opinions based on past knowledge and experience.
Read the post, not just the title
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 06-07-2016, 07:50 PM   #9
Zeke.Malvo
Zeke.Malvo's Avatar
Drives: 1969 Mustang MaCh1
Cooling will have zero impact on dyno numbers.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtq
T56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear
Zeke.Malvo is offline   Reply With Quote
Old 06-07-2016, 08:33 PM   #10
IOMike
Drives: 2022 F150, 87 Monte Carlo
I see this as being over 650hp.
Don't forget, the supercharger is physically bigger than the z06. Is it because it has a larger plenum? Or is it larger than 1.7L? Most likely just the plenum, but they would get a lot of good press if they went bigger.
Corvette does not keep the Camaro down, plus there may be a zr1 coming.
IOMike is offline   Reply With Quote
Old 06-07-2016, 09:11 PM   #11
2cnd chance
I agree, however the question is not clear. Does he want a true measurement or the actual performance on a track? I see his poll asking for rwhp, but it still begs the question of "putting power down" in a practical sense.
Old 06-07-2016, 10:58 PM   #12
Jeffro19
Jeffro19's Avatar
Drives: 2018 ZL1 6M, Silverado High Country
I think what the OP is asking is which car will put useful power to the ground? Say on a drag strip or at the track.
Previous Camaro's - 2002 Z28 6 spd manual, T tops, Sebring Silver - 2010 2SS 6 spd manual, Cyber Gray Metallic
Current Vehicles - 2018 ZL1 Red Hot 6 spd manual, Carbon Hood, Sunroof
2019 Silverado High Country, Daily Driver
Jeffro19 is offline   Reply With Quote
Old 06-07-2016, 11:17 PM   #13
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
ZL1 will put down more to the wheels stock for stock than the zo6 on the dyno. 2 things will make that happen... Tune on the ZL1 will be a bit more aggressive from the factory because GM knows how to tune them better and also IF the ZL1 will have Tri-y headers. Those 2 things make quite a bit the difference. But keep in mind... Just because it will put down more power than the C7 Zo6, does mean it will be faster. Weight, aero etc, even if the other variables like weather is perfect. I am willing to bet that ZL1 stock tires are 100 times better than the NON-ZO7 tires are when it comes to putting down power though.
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 06-07-2016, 11:38 PM   #14
fattyz28
fattyz28's Avatar
Drives: 20 2SS 1LE
I really meant dyno numbers for the LT4, since the SS put down more than the C7 with the same power plant (LT1).
I can't foresee the the ZL1 beating the Z06 down or on a track due to the aerodynamics and other aspects that the Vette has over the Camaro.
I hope that clears it up.
