Old 04-18-2018, 05:28 PM   #1
jrs580
jrs580's Avatar
Drives: 2016 2ss
Upgrading the A.C. compressor
Since I put in the killer chiller the a.c. likes to blow warm at an idle when it's hot outside. Anyone have any ideas of an upgraded compressor or smaller pulley?
2016 Black Camaro 2SS A8 Red interior
Modifications:Red powder coated Whipple LT1 blower, Aeroforce interceptor w/vent pod, FI Interchiller, Roto-Fab breather, ARH full length headers with high flow cats, JRE AFM modules, Borla S type NPP exhaust, Mishimoto catch can, JMS fuel pump voltage booster,MRR 017 1LE replica rims, 285/35zr20 Goodyear Eagle F1 G:2 front, Toyo r888r 325/30/zr20 back, Phastek blackout kit for the reflectors, GM dark tail lamps, Blendmount radar detector mount with Escort Redline hardwired in.
jrs580 is offline   Reply With Quote
Old 04-18-2018, 07:13 PM   #2
ctrlz
I would start by asking what your high and low side pressures are for a given ambient. If I understand this install correctly, you had to open up the AC system. Was it pumped down adequately and recharged by weight? And are the radiator fans working correctly? Bad A/C performance at idle is often a sign of bad airflow across the condenser or undercharge.
Assuming there are no glaring problems with how you put things back together, I would think new compressor or pulley is not the right approach to restoring good performance. You need to get heat out of the condenser. Maybe change the fan blades, install uprated fan motors, or install a bigger condenser in that case.
Interesting problem.
Old 04-18-2018, 07:25 PM   #3
jrs580
jrs580's Avatar
Drives: 2016 2ss
Pressures are good, I just checked them today. It was a little low so I added about a half a can.
Old 04-18-2018, 07:34 PM   #4
Atomic Ed
Drives: 2001 Audi TT, 2016 Camaro
PM Dave1SS. He has worked out all of the bugs on the Killer Chiller.
Atomic Ed is offline   Reply With Quote
Old 04-18-2018, 07:43 PM   #5
GT-ER
Drives: 2018 Camaro ZL1
What is good? What was your low side readings, high side and ambient temp. Also, if charged by weight, it could be undercharged as the system is now larger is it not?
GT-ER is offline   Reply With Quote
Old 04-18-2018, 09:12 PM   #6
jrs580
jrs580's Avatar
Drives: 2016 2ss
I got the pressure as close as possible to good. Ambient air temp 75, low side 42 high side 205.
Old 04-18-2018, 09:13 PM   #7
jrs580
jrs580's Avatar
Drives: 2016 2ss
How do you send a message to someone directly?
Old 04-18-2018, 10:49 PM   #8
Atomic Ed
Top right corner. Your welcome statement.
Old 04-19-2018, 11:44 AM   #9
ctrlz
Link to Daves1ss's thread:
http://www.camaro6.com/forums/showthread.php?t=503690
Old 04-19-2018, 07:05 PM   #10
rjacobs
Drives: none
I wasnt aware that the new refrigerant was even available outside of the pro environment yet... i.e. you cant buy it at autozone, oreilly, napa, etc...
So what did you add "1/2 a can of"? R134a? Because thats the wrong freon.
rjacobs is offline   Reply With Quote
Old 04-19-2018, 07:18 PM   #11
SnakeEyeSS
SnakeEyeSS's Avatar
Drives: Camaro 2SS & ZL1
Whoops double
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red
SnakeEyeSS is offline   Reply With Quote
Old 04-19-2018, 07:26 PM   #12
SnakeEyeSS
SnakeEyeSS's Avatar
Yup, you need R-1234yf.
Well, actually you probably need a few other things. Like a vacuum down and a system flush, maybe, probably?, a new orifice tube if you used the wrong freon.
Cars should have a sticker for refrigerant type under the hood. On the 6th inside the bottom side of the hood corner close to the steering wheel/left side of vehicle, right side when you are looking at it. (Varies by car model, my Honda and Mazda have it sround the radiator aroud or coolant expansion tank). They usually also have the capacity listed on that sticker, but some cars don't.
Old 04-19-2018, 07:54 PM   #13
TrekGTO
TrekGTO's Avatar
Drives: 05 GTO / JETTA TDI
A proper Chiller system will have no effect on vent temperatures. Jrs580 Email me if you want to know what is going on.
TrekGTO is offline   Reply With Quote
Old 04-20-2018, 08:58 AM   #14
ctrlz
Hey, no secrets, please! I would love to know what's going on. You can redact the names to protect the innocent!
