Roto-Fab
Old 04-19-2024, 10:15 AM   #1
ScottyCinco
Drives: Camaro LT1 RS V6
Question CAMARO OVERHEATING WHEN IDLE ONLY
So I’ve been having a issue where the Camaro only overheats when idle , I took it to a shop they told me it was the computer not telling the fans to kick on and now i have to take it to the dealer , has anyone else had this issue before I get ****ed with no lube by GM?
ScottyCinco is offline   Reply With Quote
Old 04-19-2024, 01:21 PM   #2
gtstorey
What do you call overheating? What temperature? Or does water actually boil out?
Old 04-19-2024, 02:00 PM   #3
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Sounds like the shop made a decent assessment. That's what I was about to say.
Old 04-22-2024, 12:11 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Same here. If it is overheating at idle, probably the fans not turning on, because while you're moving, you have air flow to cool it down. I would have someone check the fan connectors and or fuses/relays for them. Good luck.
Old 05-03-2024, 05:10 PM   #5
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
Did they scan the ECM? What code(s) did they have?
Mouse330 is offline   Reply With Quote
Old Yesterday, 06:21 AM   #6
bsn
Drives: 2013 ZL1
Long shot but try disconnecting the battery for a few hours, sometimes the ECU's get confused.
bsn is offline   Reply With Quote
ac fix, dealer, repair costs, repair failure
