Old 01-08-2014, 05:31 PM   #1
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
LG Motorsports ZR28 Wheels
Looking for new wheels for your Camaro? Check out the ZR28 by LG Motorsports.
Features
  • Front 20x10
  • Rear 20x11
  • Satin black finish
  • Includes LG center cap
  • Accepts OEM TPMS
  • Accepts OEM lug nuts
  • Fits V6, SS, 1LE, and ZL1 Camaro
Be sure to state your a Camaro 5 Member when ordering.
Anthony @ LG Motorsports is offline   Reply With Quote
Old 01-08-2014, 05:40 PM   #2
Piccione Performance
Piccione Performance's Avatar
Drives: 2010 2ss/rs & 2014 Stingray
Are they Forged like the OE wheels? How much do they weigh?
Piccione Performance is offline   Reply With Quote
Old 01-08-2014, 06:09 PM   #3
We use a high pressure casting method....to reduce the costs of the wheels to approx 1/2 that of the stock ones. Weight is still within a few lbs of the OEM wheels. Exact I believe to be 32.4 front and 32.9 lbs rear.
Old 01-08-2014, 10:57 PM   #4
Burn Notice24
Drives: 2012 Camaro Convertible
Mine look great on my red convertible! Anthony was really helpful and answered all my questions. (Even the stupid ones) I would highly recomend these if you're looking for this style of wheels. I'll try to put some pictures up when I wash my car this weekend!
Burn Notice24 is offline   Reply With Quote
Old 01-09-2014, 01:53 PM   #5
There is never a stupid question and we are here to help!
Can't wait to see pictures!
Old 01-09-2014, 03:06 PM   #6
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
On the website, we're only allowed to buy the 20x10 Front and 20x11 Rear set. Can we do a 20x10 package for all 4? What offset would you recommend for a square setup like that (I'm assuming something in the 25-30mm range) so I would be able to rotate tires?
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 01-09-2014, 03:59 PM   #7
You can do it that way, but you would be running four front wheels on the car and the rear fitment at that point becomes a bit on the aggressive side. I have seen guys do it though with a 285 tire front and rear like the 1LE's.
To do custom combo's you would have to call the order in.
Old 01-09-2014, 04:31 PM   #8
LuSe4
LuSe4's Avatar
Drives: 2013 Camaro 2SS RS LS3
I literally just searched out this thread to ask the same question about (4) 20x10 availability.
When you say "aggressive", are you referring to the handling?
Would the price be the same as tbe staggered set?
Thanks!
-2013 Summit White over Inferno Orange 2SS RS-
-2014 White Diamond Silverado Z71 Crew Cab Short Box-
LuSe4 is offline   Reply With Quote
Old 01-09-2014, 04:54 PM   #9
Thanks!
Pricing would be roughly the same. By aggressive I mean fitment to the rear quarters. It is right at the edge of the body lines.
Old 01-09-2014, 04:58 PM   #10
LuSe4
LuSe4's Avatar
Oh, OK. Thanks!
Old 01-09-2014, 06:09 PM   #11
bionick
bionick's Avatar
I'm running 20x10 275/40/20 all corners and no fitting issues
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
Old 01-09-2014, 06:48 PM   #12
LuSe4
LuSe4's Avatar
Pics?
Old 01-09-2014, 08:08 PM   #13
bionick
bionick's Avatar
Pics?
http://www.camaro5.com/forums/showthread.php?t=336184
Go to post 12
Old 01-09-2014, 08:37 PM   #14
bionick
bionick's Avatar
