Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > Wheels | Tires | Suspension | Brakes
Old 10-24-2013, 01:51 AM   #1
GQ4Life
Drives: 2010 Camaro SS LS3
My Tire Temp monitor Doesnt Work
It always says warm no matter what LoL..
Pretty sure I goto the dealer they going to have no clue. and I dont want to leave it there forever so they can see it is cold after sitting over night..
Anyone else notice this on theirs?
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 10-24-2013, 02:48 PM   #2
GQ4Life
This is when it should say warm
Sent From The Q on the Galaxy S4
Old 10-24-2013, 02:50 PM   #3
occar
Drives: n/a
Mine has yet to say anything but warm as well.
Software issue potentially?
occar is offline   Reply With Quote
Old 10-24-2013, 03:01 PM   #4
GQ4Life
Yeah the calibration for temp is off.. u should be allowed to adj warm & hot temps urself to allow for different tires needing different temps..
Im tempted to spray can air upside down lower temp to below zero see when it would say cold lol
I called my dealer aksed them to call gm corvette rep..
Old 10-24-2013, 03:03 PM   #5
GQ4Life
I seen vids where they showed cold then went to warm when driving & they were in freezing weather..
Old 10-24-2013, 09:28 PM   #6
purpleRac3r
purpleRac3r's Avatar
Based on several days of daily driving with cold mornings and warmer afternoons, it seems the cold/warm point is right around 40 degrees. This makes sense as the tires are not intended to be driven under 40. According to the owner's manual, "warm" indicates the temp range for normal driving conditions. I don't believe you're experiencing any kind of malfunction.
purpleRac3r is offline   Reply With Quote
Old 10-24-2013, 09:41 PM   #7
GQ4Life
I would think warm would start on what it considered warm for a tire temp when it has grip.. starting lowest 60..
well so far i checked at the lowest 44 degrees..
i should park the car outside again.. then check tire temp then check tire temp monitor..
42 degrees right now suppose to be 39 degrees at midnight..
Operation Tire Temp has commenced
Old 10-24-2013, 09:55 PM   #8
purpleRac3r
I did think the same, that it wasn't working, until it dropped below 40 here. Low and behold, "cold" showed up. And believe me, the tires don't grip well until they warm up a little. Do keep in mind, the sensors are for the tire temp, not the air temp. The display also isn't using just the tire temp from the sensors, but several other factors too, to show the overall state they are in. Per the manual, "hot" indicates ideal range for best track performance, not that the tire is dangerously overheated, etc.
Old 10-24-2013, 10:16 PM   #9
GQ4Life
Yea the pirelli's r the same way when freezing. All performance tires r..
Yeah. I know it reads tire pressure sensor temp with sone othe things to guess tire temp..
Yeah figure hot means tire nice hot & sticky since track vid showed hot..
Im check later when in 30s.. my laser thermometer tells temp of surfaces so I'll use that on tire again...
anyone find out yet what tire temp they turn hot??
Old 10-25-2013, 06:11 AM   #10
GQ4Life
Should say cold before freezing
Old 10-25-2013, 08:25 AM   #11
occar
Drives: n/a
Today was colder.
Turn on car: says warm
Drive maybe 1/3 mile: says cold (had been on other menus in the mean time)
Drive about 4 more miles: remains saying cold
It looks like it works, but doesn't work until you drive it a little.
Old 10-25-2013, 07:43 PM   #12
GQ4Life
Today was colder.
ive driven.. never changes.. lol.. i think my configured bad.. mine wont say cold till freezing and ur not even suppose to drive on them anyway lol
Old 10-27-2013, 02:28 PM   #13
Chevrolet Customer Svc
Chevrolet Customer Svc's Avatar
Drives: GM Vehicles
Hey GQ,
What did your dealer say? Did they speak to anyone at GM?
Keep us posted,
Kelly J.
Chevrolet Customer Care
Chevrolet Customer Svc is offline   Reply With Quote
Old 10-27-2013, 04:12 PM   #14
GQ4Life
Originally Posted by Chevrolet Customer Svc View Post
Hey GQ,
Keep us posted,
Kelly J.
Waiting to talk to service tomorrow see if they got in touch with gm corvette rep.. at 36° tire temp when not even suppose to drive it at 32° should say cold
