03-18-2024, 10:58 AM | #15 |
Petro-sexual
Before adding the aux' pump, on the stock Maggie 90mm upper, my low side was dropping in the Summer on 91 (E10). High side wasn't falling yet, but I also was only in the throttle for a single-gear hit, not going through the gears at WOT, so the high side could probably start dropping at that point.
You didn't mention (that I saw) an aux' pump, or a booster, and if that's the case, I wonder if that could have contributed as well. It looks like you're taking care of that this time though, so that's a good thing. JMO.
03-18-2024, 11:15 AM | #16 |
No, because you make sure that you have a robust enough fuel system that has enough head room for weather not to matter. We try not to live on the edge because the chance of failure is high.
03-18-2024, 11:18 AM | #17 | |
Edit: Katech Mike beat me to the punch.
03-18-2024, 11:21 AM | #18 |
For me, the AEM X-SERIES WIDEBAND UEGO AFR GAUGE KIT is a must. It makes it very easy to see your AFR in real-time. In the OP's case, surely it would have provided sufficient warning if the engine went lean
'20 ZL1 1LE A10,
03-18-2024, 11:51 AM | #19 |
Correct, and the best part about that gauge is it communicates through the canbus network, so your AFR readings populate into your HP Tuners datalog. You can easily see what your AFR readings are doing over the entire run.
03-18-2024, 12:49 PM | #20 |
Snackbar Tuning
Unfortunately, a wideband isn't enough when it comes to the DI system. If End of Injection drops into the danger zone where you have detonation, preignition or inefficient combustion, the Wideband will still read a generally safe Lambda value but in reality your about to send a rod through the block.
GM Gen V Calibrator
03-18-2024, 12:59 PM | #21 |
Vengeance Racing is the same way. When I asked about doing tuning my car for flex fuel, they didn't want to do it for the same reason.
03-18-2024, 01:04 PM | #22 |
03-18-2024, 01:10 PM | #23 | |
Having FUN in the SUN...
Makes sense... So in that case... perhaps rail pressure on the banks idash with an alarm set for low pressure?
03-18-2024, 01:42 PM | #24 | |
Snackbar Tuning
Since SOI/EOI is directly affected by Rail Pressure, it would definitely be alarm worthy to monitor Rail Pressure.
GM Gen V Calibrator
03-18-2024, 03:08 PM | #25 | |
That being said, I can see big name shops not wanting to deal with it because a lot of folks today have a hard enough time tying their shoes. Heaven, forbid they have to take an extra minute when they fill up to check Ethanol percent.
2016 NFG 1SS A8
03-18-2024, 03:28 PM | #26 | |
Drives: 2017 ZL1 Join Date: Mar 2022
What is the rail pressure we should be looking for in logs to NOT drop below? I pull logs about once a month on my car and look over them but not sure on the things that stick out that I should look for unless they look way out of bounds? PS these are the threads I come to this forum for. Great conversation leading to ideas. |
03-18-2024, 04:02 PM | #27 | |
high side- 2900psi IPW < 6.0 ms On LT4 fueling with low side upgrade, I will sometimes up the rail pressure to 3200psi if the injector pulse widths are on edge (6.0ms). One of the most critical things to monitor imo is IPW. Because if the injectors are opening up past 6.0ms you are getting outside of the window to spray fuel on time. That is when bad things can start to happen. If you have enough injector, then the rail side technically can dip below commanded and still be fine IF and Only IF the IPW's are still in range.
2016 NFG 1SS A8
03-18-2024, 06:52 PM | #28 | |
Drives: 2023 Camaro ZL1 Join Date: Apr 2023
Should I run e50 now because of my aux pump and will it be ok now with that pump if temps drop? Tune for e50 and when I want to run e I should just full it up to e30 or e35 so it isn’t maxing out the fuel system? Should I just not run e at all because it’s too stressful and catastrophic? 🤣 What guage can I get to see both e % and also fuel pressure? I can only seem to find one that reads either only fuel pressure or either only e %. will want one 100% |
