01-04-2018, 10:04 AM | #1 |
Drives: 2014 camaro 2ss Join Date: Dec 2017
Brake pad lifetime
How many miles did your original brake pads last?
01-04-2018, 10:08 AM | #2 |
Fast Cars and Old Guitars
This will probably get a fairly wide range of answers. But now I'll go all politically incorrect - If more women drove Camaro's the answers would be shorter mileage. Based on my experience! If my step daughter drove mine it would need a new set at 7500.
01-04-2018, 10:41 AM | #3 |
Drives: 69 SS Camaro 2019 Corvette GS Vert. Join Date: Jan 2017
You should get 60,000 to 70,000 miles out of a set of pads if you don't ride the brakes or do any aggressive driving that requires aggressive braking. In my 46 years of driving I have observed that under normal driving conditions you will get less brake pad mileage from an automatic car than a manual because you use the manual transmission to slow yourself down before braking. Our 2014 Malibu which is an automatic has 52,000 miles on it and the pads still have 1/3 of their useful life left. They should make it to 65,000.
There is a fine line between hobby and obsession and I think I crossed it!!
01-04-2018, 10:47 AM | #4 | |
corner barstool sitter
There's around 90,000 miles on her Subie and I finally need to do a brake job on it once the weather clears/warms up a bit. Norm
01-04-2018, 12:21 PM | #5 |
Drives: 2015 2LT/RS BVM Join Date: Mar 2015
Yeah, I do a lot of engine braking, so my pads don't have a ton of wear. At ~56k and no issues so far. Still on the factory pads
01-04-2018, 12:26 PM | #6 |
Drives: 2015 SS, 2006 CTS-V (wrecked...) Join Date: Jul 2017
My OEM pads are work out at 35k miles... I bought the car used 5k miles ago and HOPE it's only the first set of pads that have been burned through. I'm starting to get the idea this car had a rough life before I got it.
01-04-2018, 01:30 PM | #7 |
Drives: 2015 SS/A6 Join Date: Feb 2016
20K miles on stock Brembos pads and they look like they have at least another 20k in them (I checked last weekend when I painted my Calipers Also one owner car)
Before that My V6 Camaro had stock pads with 47K miles and still had another 30 in them and I tracked and autoX the V6 every 3 months. (Also 1 owner car)
2015 Camaro SS/A6--Roxy MOD'S
*Rear Muffler Delete *VMAX Throttle Body *Speed-Engineering Headers / No Cats *Catted Magnaflow X-Pipe *BMR Toe Rods *BMR Xtreme Ant-Roll Kit *BMR Trailing Arms *CAI Cold Air Intake *TUNED BY JAY @ KRAFTSWORKS EXCELL |
01-04-2018, 04:24 PM | #8 |
376 cubic inches of fun
Depends on highway vs city miles.
After 60,000 miles, mine are at most half worn. And because I don't drive in winter salt conditions, the rotors look good too. |
01-04-2018, 04:47 PM | #9 |
Drives: 2015 Chevy Camaro 2LS Join Date: May 2017
I dunno how long they will last, but I am changing mine come spring. I want a better performing pad with less dust.
01-04-2018, 05:01 PM | #10 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Good luck. The two aren't mutually exclusive. Brake dust is a sign of work being done. Generally, pads that don't dust, don't bite well.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
01-04-2018, 05:49 PM | #11 |
01-04-2018, 06:17 PM | #12 |
Drives: 13 Camaro Join Date: Oct 2016
Also depends on how much and how often traction control kicks in, including stability control.
01-04-2018, 06:21 PM | #13 |
That makes sense I suppose since brakes are involved. I’m sitting here next to the ol girl now and there’s a clear step on the outside of the front rotors. It’s got 7500 miles on it. And though I downshift fairly often, I tell myself that brakes are WAY less $ than a tranny. (it’s an auto)
01-04-2018, 08:32 PM | #14 |
Drives: 14' 2ss convertible Join Date: Oct 2017
Just turned 46k about a 1/3 of the pad is left. L99
