10-11-2017, 12:27 AM | #1 |
Drives: 2016 Camaro 2SS Join Date: Jun 2017
I feel dealer has different opinions on oil & brake fluid change for track
Today I went to dealer for automatic transmission fluid level check for track. The service adviser told me no need to check before track day, just bring it back after first track day and they will check if everything is fine.
Then I asked him about oil change and brake fluid change. He told me if I do track day once a month or less frequent and also drive it on the street regularly, what he suggests is to do oil change after each track day but with 5W30 oil. My question is, what's the problem of driving on the street with 5w40 oil. He said 5w30 will be OK if I don't track it often. As for brake fluid change, he suggests to flush the brake after each track day with DOT3 (or DOT4 if necessary) brake fluid. I remember on this forum people usually just bleed the brake after each track day and flush the brake every year. Is that true? He got all the information from some GM website for dealers. I'm familiar with both the dealer and that service adviser. I trust him but I really have doubt about the suggestions he gave today. What do you think? Thanks! BTW, I'm new to track driving and I'll be going for my first track day (NASA HPDE) at the end of this month. |
10-11-2017, 02:52 AM | #2 |
Drives: 17 Hyper Blue SS 1LE Join Date: Aug 2017
Driving on street is fine with the 5w40.
I don't know about the auto trans but we don't have to mess with the manual trans. Recommended change diff fluid before first track day and every 10? Track hours afterwards. The brake fluid will depend what you're using. I know lots of people who flush Everytime with ate blue. Every 2-3 track days with motul rbf600 and then once a season with Castro srf with just bleeds between each. |
10-11-2017, 04:56 AM | #3 |
Drives: Chevy Join Date: Jun 2017
You went to the dealer so they can check trans fluid level?
10-11-2017, 09:15 AM | #4 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
10-11-2017, 09:16 AM | #5 |
corner barstool sitter
I think I recall hearing that there's a specific procedure for checking the level for track duty.
We were typing at the same time, Eric. Thanks for the confirmation that I wasn't imagining it. Norm
10-11-2017, 09:21 AM | #6 |
#becauseracecar
If this is your very first track day you should be fine with the stock fluid. If you do continue to go however I would definitely change to DOT 4. I would however put Dexos 2 oil in before the track day JUST IN CASE something goes wrong with the motor. You don’t want to give GM any reason to try and deny a warrantee claim. I would also have the service advisor put in writing that it’s ok to run 5w-30 on the track if you do decide to keep it in the car for the track day so you have that as well. 5w-40 is 100% fine to run all the time.
Also, I recommend everyone put the track day backing plates and scoops on before anytrack days. Without them the brakes on this car get almost no air and overheat quickly. I just leave the track backing plates and scoops on all the time. In San Diego you’ll be fine doing this as well. |
10-11-2017, 02:15 PM | #7 | |
10-11-2017, 02:25 PM | #8 | |
I guess for the first time I'll use the stock fluids. I'll keep and eye on the fluid temperature and oil pressure. The manual says don't drive too hard for the first time. Plus, I won't be able to drive very fast for the first time anyway. Afterwards I'll switch to recommended 5W40 oil and DOT4 brake fluid As for the track day backing plates and scoops, you may not remember but I asked you about this in another thread. Then I did install them. The caliper bolts are such a pain. I ended up going to dealer to let them check if everything is fine. I'll probably ask dealer to do it if I want to install the street ones. But for now I'll leave them on there all the time Since you live in Arizona, do you go to track all year round? Will summer be too hot for the car? In another thread you mentioned you have track insurance. I'm not sure if that's necessary for me because they won't even record the lap time for HPDE 1 and 2. I'm thinking to buy insurance when I start to care about lap time. I'm not sure that's the correct mind set. What do you think? Wow, I have so many questions |
10-11-2017, 02:56 PM | #9 | |
I couldn't tell you what that keeps the fluid wet boiling point above, only that with much smaller rotors and slightly slower speeds I've never run into any episodes involving boiling brake fluid with that approach. The choice to purchase track day insurance really depends on what your comfort level is, maybe on your insurance company, and possibly your own local agent. That the laps are not being timed may not a strong enough argument that you aren't "racing" or otherwise "abusing". Norm
10-11-2017, 03:05 PM | #10 | |
#becauseracecar
10-11-2017, 03:09 PM | #11 | |
#becauseracecar
OP: I would definitely read your policy. |
10-12-2017, 12:12 AM | #12 |
Thanks Eric and Norm, now I have a plan about engine oil, brake fluid, track insurance etc.
10-12-2017, 12:34 AM | #13 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
As far as insurance, check for companies that insure race cars for a whole season. Your coverage begins as soon as you enter a track. The cost is about the same as a regular insurance. If you decide to track often and decide you wish to be covered, this is by far a cheaper way to go vs paying per day. Also, if you wish for some tips how to prep for a track event, check out Trillium BMW website at www.soBMW.ca then Schools tab top left for good tips. Some are specific to this club, but most are generic. Cheers!
10-23-2017, 09:42 AM | #14 | |
Drives: 2014 shelby Join Date: Mar 2016
https://www.milwaukeetool.com/power-...rdless/2861-22 I can change my car over to track duty in about an hour. And back in the same amount of time. This tool makes it a breeze. I use setting number 3 on the tool and give the caliper bolts three trigger bursts after contact. that is about 150 ft lbs. |
