Old 06-07-2016, 12:28 PM   #1
alvinmiles
alvinmiles's Avatar
Drives: 2011 Camaro 2SS - Black
Header install. No check engine light but stabilitrak and traction control
Installed headers. Used tuner for headers, dod delete, rear o2 delete. But now i get lights about stabilitrak, traction control with no cel. Any ideas.
Posting all mods as i go, along with other non sense.
http://m.youtube.com/channel/UCJY1FzsIqSAtCJxZdYeuz-A
alvinmiles is offline   Reply With Quote
Old 06-07-2016, 12:49 PM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Yea your tuner missed the boat, bring it back to him and have him fix it. The service stabilitytrac light can also be caused from too much timing, among other things. Best to send him a datalog.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 06-08-2016, 10:18 AM   #3
MMC
MMC's Avatar
Drives: CGM 2SS/RS, 1987 & 2014 Silverado
Check the plug wires.
MMC is offline   Reply With Quote
Old 06-08-2016, 12:41 PM   #4
alvinmiles
alvinmiles's Avatar
Even without a cel?
Old 06-08-2016, 01:34 PM   #5
keith.wilkinson.10
keith.wilkinson.10's Avatar
Drives: 2010 2SS/RS IBM
Check em
Sent from my SAMSUNG-SM-G890A using Tapatalk
keith.wilkinson.10 is offline   Reply With Quote
Old 06-08-2016, 04:02 PM   #6
1KillerSS
1KillerSS's Avatar
+1 should be number 1 thing to do
Even without a cel?
Yes a miss fire wont always cause a CEL, but will trigger a Stabilitrac message.
Build thread
Old 06-08-2016, 05:27 PM   #7
G701LE
G701LE's Avatar
Drives: 2010 2SS/RS L99 IBM silver stipes
Did you undo the steering shaft when you installed the headers?
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough....
G701LE is offline   Reply With Quote
Old 06-08-2016, 06:25 PM   #8
alvinmiles
alvinmiles's Avatar
I did
Old 06-08-2016, 06:38 PM   #9
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
This. I got the same lights and then I realized I left one plug wire off when tightening down the header bolts.
jayno20 is offline   Reply With Quote
Old 06-09-2016, 01:44 PM   #10
alvinmiles
alvinmiles's Avatar
just finished with new plug installation. made sure all plug wires were snug. usually the code throws as soon as i start rolling. thought it was fixed....for a moment.
its back.
Old 06-09-2016, 02:19 PM   #11
C62SSFTW
Drives: 2015 Camaro 2SS
"G701LE" is on the right track. I used to own a Pontiac G8 GT (witch shares a platform with us), I saw this happen many times with other people when doing headers. We had to disconnect the steering shaft to install the headers. When you reconnect it, it needs to be put back in the exact same position as when it was removed. I used a black sharpie to mark this. If the shaft turned to a different position be fore reassembly, there is a sensor that detects the position of the steering to help with stability control. When miss aligned what you are describing above will happen.
If you know how much it turned by just realign it, if not, tail and error. I have also heard this may be reconfigure thought tuning software, but do not know for certain.
C62SSFTW is offline   Reply With Quote
Old 06-09-2016, 03:48 PM   #12
G701LE
G701LE's Avatar
Yes. I learned the hard way (as usual) about the steering shaft. Had to take it to someone that can "reset" or "relearn" the steering. If it is off AT ALL, it will throw these codes.
Old 06-09-2016, 03:56 PM   #13
alvinmiles
alvinmiles's Avatar
Yes i think that's right. It doesn't come on until i turn left. So tomorrow I'll disconnect it and turn 1 rotation to the right. Thanks a lot guys and I'll keep u posted. Btw at least i got new plugs.
Old 06-09-2016, 06:55 PM   #14
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
I'd still check plugs/wires. Seen three camaros throw stabilitrak messages after header installs and most were loose/damaged plugs/wires
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
