TireRack
Old 03-17-2024, 09:13 PM   #1
Kxm
Drives: 2013 Chevrolet Camaro 2SS/1LE/RS
How to Replace Lifters - Guide
Hey everyone, I know that replacing the lifters seems like a simple process but when it comes to DIY I want to make sure that I do everything spot on.
I am doing a cam swap and upgrading the springs, rods, oil pump, etc. when I do so. My motor has 32,000 miles on it. I have all of the resources to do everything except pull the heads and replace the lifters and trays. I have found videos online of people doing so but they are very brief.
Are there any guides/tutorials available that provide pictures and step-by-step instructions the way robertway did his DIY: LS3 Camshaft Install guide? I have printed his off to use as a reference when I do the cam install but I don't have anything for the heads and lifters. I would appreciate any insight.
Thanks guys.
Kxm is offline   Reply With Quote
Old 03-28-2024, 11:32 AM   #2
SS_CTS-V
Drives: 2015 SS, 2006 CTS-V (wrecked...)
Here's great video on removal if the heads:
Assembly is essentially the opposite. Head torque sequence is a bit of a challenge in the car, I just did it a couple weeks ago. You will need an angle gauge, or a digital angle torque wrench.
I used the instruction guide from Trick Flow for installation:
https://www.trickflow.com/parts/tfs-...nstructionArea
Removing the liters is super easy with a magnetic pick-up tool, and the trays come right out with a couple 10mm bolts. Then new lifters drop into place, piece of cake. Most all lifter manufactures recommend soaking in oil before installation. The BTR lifters I used came in a convenient tray that I just poured the oil into.
If you are doing all of this, might as well do a trunnion upgrade too!
SS_CTS-V is offline   Reply With Quote
Old 03-28-2024, 03:12 PM   #3
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
If I was you I would invest in some arp head bolts or studs so you don't have to mess around with the tty factory bolts. They are kind of pricey but I never liked the tty bolts and the arp are reusable.
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 03-28-2024, 04:01 PM   #4
Fanch1LE
Fanch1LE's Avatar
Drives: 2015 1SS 1LE
This is a detailed write up for removing/replacing heads, from here on the forum. The write up is similar in style to the famous cam swap DIY.
https://www.camaro5.com/forums/showthread.php?t=556941
Fanch1LE is offline   Reply With Quote
