03-06-2024, 03:17 PM | #1 |
Replacing Oil Pump
After chasing some on-track oil pressure issues, going to upgrade to a Melling 10296 pump after acammer's recommendation.
What else should I do while I am in there? I realize doing probably 1/2 to 3/4 of a cam swap job, but I don't think I will go down that slippery slope right now. Is there any other recommended upgrades/updates I can do in this process?
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Mishimoto Oil Cooler, BMR Tunnel Brace, Mishimoto Oil Catch Can, MSD Plug Wires, Mishimoto Radiator and Hoses. |
03-06-2024, 05:21 PM | #2 |
You can plug the oil pan pressure relief valve.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
03-06-2024, 06:58 PM | #3 |
How many miles are on it?
03-06-2024, 08:01 PM | #4 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Don't think the 1Les have a relief. Isn't that only on the L99s?
Timing chain and tensioner can be changed as well |
03-06-2024, 09:05 PM | #5 |
2013 1SS/1LE
03-07-2024, 05:00 AM | #6 |
I'm not sure Joshmn my zl1 has it. I was assuming they all had it.
03-07-2024, 05:59 AM | #7 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
I'm probably wrong, but I thought pretty much all the gen 4 motors have them, regardless of DOD or not. I researched this a while back and that is what I found then.
To OP, don't forget new gaskets and seals in addition to what the others mentioned. It would be a good time for an underdrive pulley.
03-07-2024, 08:03 AM | #8 |
I was going to say maybe the timing chain and tensioner but I wouldn't probably mess with it at 60k miles unless you were doing a cam swap. Maybe a good time to upgrade your harmonic balancer and plug that darn relief valve in the pan for more top end oil psi.
03-07-2024, 11:31 AM | #9 | |
And this is exactly why I didn't want to venture down the "Cam Swap" road... Initially, in my GPI shopping cart was just the oil pump. Now its: - Melling Select - High Volume High Pressure 8 GPM LS Oil Pump (10296) - PowerBond - 2010-2015 Camaro SS & 99+ LSx Truck Underdrive Pulley Kit (PBU1190-SS25) - PULLEY BOLT (OPTIONAL): ARP - CRANKSHAFT DAMPER BOLT FOR LS, GEN V LT1 AND LT4 WET SUMP ENGINES (234-2503) - MAIN BELT (OPTIONAL): SERPENTINE BELT FOR 25% UNDERDRIVE PULLEY FOR 5TH GEN CAMARO W/ ELECTRIC POWER STEERING (060780) - A/C BELT (OPTIONAL): A/C BELT FOR UNDERDRIVE PULLEY (K040350) - Chevrolet Performance LS Oil Pan 2010-2015 LS3/L99 Camaro/G8 (I figured this would be a good time to do a baffled oil pan for my road course time.) - OEM Style - Timing Cover Gaskets (12633904) - GPI - OEM Style LS2 / LS3 Timing Chain Dampener (12588670) Not for Use in Dry Sump Engines
2013 1SS/1LE
03-07-2024, 09:25 PM | #10 |
I got this guy from improved racing. I think it does the job.
03-08-2024, 10:50 AM | #11 | |
2013 1SS/1LE
