Old 03-01-2019, 09:29 AM   #1
Dawid
Drives: Camaro
Camaro rs 2010 v6 long tube headers
Hi, I own Camaro 2010 rs v6. I replaced the final silencers on Magnaflow bullets and mounted the x-pipe. I would like to get a better sound yet. I wonder about the long tube headers, is there a difference between bbk, obx or ebay collectors for $ 180 will work the same?
https://www.ebay.com/itm/FOR-10-11-C...4-686492e1fb6e
The sound of my car:
https://youtu.be/U9gr1TAxKmc
Dawid is offline   Reply With Quote
Old 03-02-2019, 02:19 AM   #2
gringo
gringo's Avatar
Drives: Camaro V6
I wish the LFX could have headers. Makes me wonder if the exhaust ports in the heads can be ported out to give better flow like a header would.
gringo is offline   Reply With Quote
Old 03-02-2019, 11:29 AM   #3
MBS
MBS's Avatar
Drives: 2010 rs 2lt
I have the BBK Ceramic Longtubes with highflow cats ,sound great, had them on now for 3 years no problems
MBS is offline   Reply With Quote
Old 03-03-2019, 02:22 AM   #4
Dawid
Drives: Camaro
I wonder if long tube headers ebay will sound just as well with the original catalysts ��
Old 03-03-2019, 10:41 PM   #5
2010reddevil
Drives: 2010 Camaro 2SS Victory Red 6M
The cost would not be worth any benefit. You'd have to pull the heads off and have them sent off to Extrude Hone. For that reason alone, the LFX and every other single port engine is junk in my book.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19
Gone on 12/28/19 R I P
2010 2SS 6M Victory Red/Black (old ride)
CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back.
12.6 @ 115 SAR as of 9/19/15
Gone but never forgotten.
2010reddevil is offline   Reply With Quote
Old 03-04-2019, 10:07 AM   #6
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
ive seen some LFX cars that move and that are in the high 400+rwhp range . i wouldnt say they're junk. they're far more advanced than the LS3.
they dont make much in performance parts other and its just more difficult to find someone that works on them for that same reason.
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 03-07-2019, 10:26 AM   #7
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Same here (i gutted my cats for the SC) but love my BBK's.
Old 03-08-2019, 02:09 PM   #8
Dawid
Drives: Camaro
What could I do to change the drone effect? I have x pipe installed.
Old 03-08-2019, 03:14 PM   #9
Marklar
Drives: 2012 Camaro LS V6
If the resonated X-Pipe doesn't do enough, you probably J-pipes (aka Helmholtz resonators), for which you will need to calculate the length you will need unique to your car. There are several good forum posts here to follow.
Marklar is offline   Reply With Quote
Old 03-08-2019, 04:41 PM   #10
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Magnaflow bullet mufflers are super drony in my experience. Try magnaflow mufflers if you want to keep the sound down.
Edit: Your car also sounds higher pitched than mine, but there's multiple factors to that. Do you have a regular X pipe, or an X muffler in the center? 11386 x muffler specifically
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
DSX_Camaro is offline   Reply With Quote
Old 03-09-2019, 12:38 AM   #11
Dawid
Drives: Camaro
I usually have X in place of H. Auto sounds good after 2.500, earlier there is a buzz. I wonder if when mounts long tube headers, CAI can be improved?
Old 03-09-2019, 08:21 AM   #12
DSX_Camaro
DSX_Camaro's Avatar
Try the Magnaflow 11386 in place of that regular X. You maintain an x but it'll get the drone and rasp under control. And it'll sound a little deeper.
Old 03-09-2019, 02:53 PM   #13
Dawid
Drives: Camaro
First, install long tube headers, see what will change. I wonder if Magnaflow bullets will give as a central silencer. To buy some sensible final muffler. I wonder what the effect will be?
Old 03-09-2019, 06:16 PM   #14
DSX_Camaro
DSX_Camaro's Avatar
Adding long tubes will make it wicked loud and raspy.
