Old 09-06-2017, 09:42 AM   #1
MIDNIGHTANGEL
Back4Revenge
MIDNIGHTANGEL's Avatar
Drives: BLACK CAMARO
Send a message via AIM to MIDNIGHTANGEL Send a message via Yahoo to MIDNIGHTANGEL
Which codes commonly pop up after header installs? I have 4:
P0496: System Flow During Non Purge *** Vapor Canister Purge Valve Ill be replacing for like $25
Then:
P0420- Catalyst System Low Efficiency Bank 1 (Passenger side)
P0430- Catalyst System Low Efficiency Bank 2 (Driver Side)
P2099- Post Catalyst Fuel trim System High Limit Bank 2 (Driver Side)
The P0496 is not a code because of the headers correct? While the other 3 are I believe. And Which Codes are eliminated if custom tuned by HP tuners?
I chose my 6 with Pride..
MIDNIGHTANGEL is offline   Reply With Quote
Old 09-07-2017, 09:53 AM   #2
MIDNIGHTANGEL
Back4Revenge
Thanks guys lol
Old 09-07-2017, 02:43 PM   #3
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Have you checked for leaks? Reading on other forums that helped some but Other says that the p0420 p0430 codes plus the P0299 will need to tuned/turned off.
Old 09-07-2017, 03:36 PM   #4
MIDNIGHTANGEL
Back4Revenge
Perfect, thats what I needed to know thank you once again man- everything is
sealed.
Old 09-07-2017, 04:23 PM   #5
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
sealed.
good
