04-20-2024, 12:49 PM | #1 |
Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
Is Removing the Sound Plate Under the SC Lid Worth Doing?
For those who have removed the metal sound plate under the supercharger lid, is it worth doing in order to reduce heat soak? I've read that doing so helps, but the tradeoff, if that is a tradeoff, is slightly more supercharger whine. I've read several threads about removing the plate, but none seem to address the heat issue. I did see a video from someone who tracks his car that claims removing it reduces IATs several degrees.
2023 Summit White ZL1 M6 (delivered 10/15/23)
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
04-20-2024, 03:06 PM | #2 |
There's no heatsoak difference. Very slightly more blower whine but it's very subtle.
04-20-2024, 04:24 PM | #3 |
Thanks. Have you been able to compare IATs before and after?
04-20-2024, 05:55 PM | #4 |
In my opinion, the plate is too thin to make a difference other than dampening Sound, if that. I removed mine while installing a catch can. Personally I don’t notice a difference in sound, but I am old and deaf.
04-20-2024, 06:25 PM | #5 |
It is thin. In the video I saw the guy said that the plate was not aluminum, but possibly steel and that it held in heat more than the cover does. Do you know if the plate is aluminum or something else?
04-20-2024, 06:42 PM | #6 |
Drives: 2023 Camaro ZL1 Join Date: Jan 2016
The plate is steel with some sort of coating on it to prevent it affecting the aluminum lid.
It isn't worth your time. Although, when I pulled my lid off, I noticed that one of the bolt posts was chipped from the factory. I will install a blackwing lid eventually. |
04-20-2024, 06:42 PM | #7 |
04-20-2024, 08:29 PM | #8 | |
I've run a ScanGuage on my cars for years and one of the things I monitor is IATs (intake temperature). The closer to ambient the better.
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) Last edited by ZPirate; 04-20-2024 at 08:53 PM. |
04-20-2024, 08:40 PM | #9 |
Wasn't worth anything, imho.
Get a foster sound tube instead. |
04-20-2024, 09:39 PM | #10 |
Petro-sexual
Picked up A LITTLE more whine and is harmless. I'd do it again.
04-21-2024, 12:14 AM | #11 | |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
Same here. Took mine off when the catch can went in. I figured why not. Did it do anything....I doubt it. But it didn't hurt anything either. |
04-21-2024, 08:00 AM | #12 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
I did the same, if you want to remove for heatissues, I say go for it, every little bit counts. But if you're going for sound/whine, it's really a waste of time.
04-21-2024, 11:03 AM | #13 |
Drives: 2019 Camaro ZL1 1LE Join Date: Apr 2018
There's a verrrry slight audible difference in SC whine, but definitely not as much as an aftermarket lid. I also had a rotofab as well.
04-21-2024, 11:18 AM | #14 |
NYTMARE23
Drives: Black 2023 Chevrolet ZL1 A10 Join Date: Oct 2022
I feel my CAI gave it more of a noticeable whine than taking off the plate did...not worth removing it if you're looking for "more" whine with a CAI installed.
2023 A10 ZL1 "NYTMARE"
