TireRack
Old 06-10-2011, 12:13 PM   #1
TOMS1SS
Drives: NA
Recommended Fuel Myths (All Engines)
Alright, all this BS I've been seeing with a lot of myths on this forum about what fuels to use. The one that gets me is saying 93 Octane is required for the LS3 and L99. I've seen lots of people ask the same questions about Octane over and over again when the answers are contained in the last place people think to look; the manual. Don't worry LTT people the manual has you covered also. Here it is word for word from the manual itself section 8-44 Recommended Fuel:
If the vehicle has the 3.6L V6 engine (VIN Code V), use regular unleaded gasoline with a posted octane rating of 87 or higher. If the octane rating is less than 87, an audible knocking noise, commonly referred to as spark knock, might be heard when driving. If this occurs, use a gasoline rated at 87 octane or higher as soon as possible. If heavy knocking is heard when using gasoline rated at 87 octane or higher, the engine needs service.
If the vehilce has the 6.2L V8 engine (VIN Code W) or the 6.2L V8 engine (VIN Code J), use premium unleaded gasoline with a posted octane rating of 91 or higher. For best performance, use premium unleaded gasoline with a posted octane rating of 93. You can also use us regular unleaded gasoline rated at 87 octane or higher, but the vehicle's acceleration could be slightly reduced, and a slight audible knocking noise, commonly referred to as spark knock, might be heard. If the octane rating is less than 87 a heavy knocking noise might be heard when driving. If this occurs, use a gasoline rated at 87 octane or higher as soon as possible. Otherwise, you could damage the engine. If heavy knocking is heard when using a gasoline rated at 87 octane or higher, the engine needs service.
- First lets clear something up about 93 octane. While yes you'll get slightly better performance in your L99/LS3 it is likely a minimal benefit and probably a waste of money unless your going to racing or something to that effect. The spec for the L99/LS3 is clear as day 91 octane. It drives me nuts when I see people on this forum say otherwise especially when the difference per gallon between 91 and 93 octane can be .30 cents plus on the gallon.
As for the part about 87 octane being used in the LS3/L99 the engine computer retards the spark to compensate for the lower grade fuel. Commonly people here on Camaro5 complain that their car has reduced performance when the accidentally put 87 octane in and go back to 91 on the next tank. This is because the computer has not reset for the 91 octane and remedy I've seen for resetting the computer would be pulling fuses or unplugging the battery.
For the LTT guys sometimes I see stuff about using 89 or 91 octane in your cars. While it doesn't say anything about using a higher octane, why would you dump a more expensive fuel into your car when you'll get factory performance at 87?
Old 06-10-2011, 12:17 PM   #2
CamaroKid300
ace5.org
CamaroKid300's Avatar
Drives: 2017 ZL1 M6
This is nice to have this all in one post. Thanks.
However, I sense some flaming in your future.
Stock...For Now.
CamaroKid300 is offline   Reply With Quote
Old 06-10-2011, 12:21 PM   #3
TOMS1SS
Drives: NA
So do I. Personally all I really take issue with people saying that 93 octane is a requirement for the LS3/L99 when people ask (who honestly don't know) what fuel to use. If some wants to use 93 octane because they want to, I don't have a problem with that by any means its just not the required fuel.
Old 06-10-2011, 12:23 PM   #4
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
Oyi....You might want to do some research on why Arizona has 91 octane fuel. I know the answer, but I want you to look it up. You'll get more out learning about it and why we have it here vs the east coast, south and some northern states.
armysig is offline   Reply With Quote
Old 06-10-2011, 12:24 PM   #5
irocnroll
irocnroll's Avatar
Drives: '91 RS Vert, '11 Grand Cherokee
I totally agree with your post, but as said above this will turn into flame war.
irocnroll is offline   Reply With Quote
Old 06-10-2011, 12:24 PM   #6
CamaroFemme
CamaroFemme's Avatar
Drives: 2010 Black Camaro 2SS/RS
It's in the manual that at least 91 needs to be put in the V8 or it WILL go into the lower performance table, and you have to do a fuse pull to get it to reset. I can verify all this from personal experience from when someone accidentally put 87 in my tank.
Edit: I've actually never seen someone say 93 was a requirement.
My boyfriend don't mind it.
CamaroFemme is offline   Reply With Quote
Old 06-10-2011, 12:25 PM   #7
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
I use the 89 octane in my LLT because it is actually 10 cents cheaper here in Iowa. Of course, it has 10% ethanol blend. I have used since day one without any issues.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts
BenningJ is offline   Reply With Quote
Old 06-10-2011, 12:27 PM   #8
CamaroKid300
ace5.org
Drives: 2017 ZL1 M6
89 is cheaper than 87?
Wut?
Stock...For Now.
Old 06-10-2011, 12:28 PM   #9
TOMS1SS
Drives: NA
True that is what it say, the battery one came from Fbodfather so who am I to say that won't work also?
Old 06-10-2011, 12:29 PM   #10
TOMS1SS
Drives: NA
Wut?
The more ethanol in the blend the more money at the pump.
Old 06-10-2011, 12:30 PM   #11
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
In the past two years, I don't recall very many people saying 93 was required. Also it has been proven by the V6 guys, there is a slight performance gain using premium fuel although it may not be cost effective.
SlingShot is offline   Reply With Quote
Old 06-10-2011, 12:31 PM   #12
UT-Engineer
Just Cruisin'
UT-Engineer's Avatar
Drives: 2010 Synergy Camaro
i stick with 87 for my V6 but there is a difference when using 91/93... i just dont think its worth the cost.
2010 Synergy Green Camaro
25% Tint - CGM Painted GM GFX - 20" Niche M102 Wheels
UT-Engineer is offline   Reply With Quote
Old 06-10-2011, 12:32 PM   #13
BATMANs
Drives: GTO & NSX
I run 91 octance california gas from COSTCO in both my blown cars (see below). No issues or blown engines.
2005 GTO Maggie, Forged engine, CAI, Kooks LTH, Magnaflow, Billet Pro shifter, LS7 clutch, 245/275 18" on Petrol Octane, Addco Sways, Koni Yellows, King Springs, Whiteline bushings, EBC Red, X-drilled/slotted rotors, SS brake lines, 55w HID, PLX gauges
1993 NSX Kenne Bell 2.1, Laminova IC, sway bars, NSX-R chassis bars, and non-compliance toe links, Tien EDFC, STMPO exhaust & brake ducts, RM Racing headers, K&N/Cantrall intake, Enkei RP03 17"18", APR GTC-300
BATMANs is offline   Reply With Quote
Old 06-10-2011, 12:32 PM   #14
Supercharged SS
Drives: 2010 Camaro
Who buys an SS and then wants less performance out of it? If I wanted less than what I bought I would have bought the V6.
Supercharged SS is offline   Reply With Quote
Fuel: getting it right the first time S-eatin-grin Forced Induction - V8 45 08-30-2012 01:22 PM
MPG for the Z28 OPP Camaro ZL1 Forum - ZL1 Specific Topics 71 12-08-2010 03:00 PM
Lethal Performance/ Fore Precision Fuel Hats- CHECK THIS THING OUT Jared@Lethal Forced Induction 3 08-12-2010 11:30 AM
Generation V V8 Engines Update!!! Mr. Wyndham General Automotive + Other Cars Discussion 29 07-08-2010 03:05 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
