dave@hennessey
Old 11-06-2013, 06:50 PM   #1
jrpxxii
jrpxxii's Avatar
Drives: 2010 Camaro SS/RS 427ci
Need a shortblock for boost
Im looking for options on a shortblock preferably RHS or ERL block built at 9:8:1 for big boost and big power. All of you engine builders out there get me an estimate for a shortblock that will hold up to approx. 2500rwhp as I am mounting an F3R-136 to it and needing a shortblock and want to see if anyone on here can hook me up.
jrpxxii is offline   Reply With Quote
Old 11-06-2013, 07:03 PM   #2
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Call Erik Koening at HKE. He can do anything. I have his cell # if you need it. Im sure you know who he is. Im pretty happy but im only gonna be at 1200rwhp.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 11-06-2013, 07:09 PM   #3
jrpxxii
jrpxxii's Avatar
Will do as I've heard nothing but good things about HKE
Old 11-06-2013, 07:30 PM   #4
LSXaddict
LSXaddict's Avatar
Drives: 1ss in Blue Ray Metallic
2013 1SS M6 with Flowmaster Pro 10 axle back and CAGS shift skip eliminator
LSXaddict is offline   Reply With Quote
Old 11-06-2013, 07:30 PM   #5
BullF-16
BullF-16's Avatar
Hey Jason, what size FMIC were you running with your F2? Im going TT and 1100-1200rwhp soon and am upgrading intercoolers but need something that wont completely block my radiator since i plan to road course the car. I was looking at the procharger 1300hp unit that is only 12.5" tall but is deeper at 4.5" thick vs only 3" that im running now. Both are 27inches wide.
Did you have fitment issues, if so what did you guys have to fab up. I assume the bumper may have to swapped over to tubing....
Old 11-06-2013, 07:34 PM   #6
BullF-16
BullF-16's Avatar
Originally Posted by LSXaddict View Post
Its funny, because when i was typing only 1200.....i had to ask myself, does that sound right? But compared to 2500rwhp its pretty accurate.
Erik can build whatever anyone needs. It just takes a while.
Old 11-06-2013, 07:36 PM   #7
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Have you considered the IC that ECS uses? Their's mounts vertically. It's goes from bottom to top, and allows the sides of the radiator to still be exposed.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 11-06-2013, 07:41 PM   #8
jrpxxii
jrpxxii's Avatar
I ran the standard race IC procharger has and yes I have tubing across front and allows plenty of airflow. My car with the f2 would never go over 176
Old 11-07-2013, 12:02 AM   #9
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Kurt Urban....NRE...... Proline..
http://www.prolineracing.net/engines...x-mozez-3300hp
I sent you a Pm.
JLE58 is offline   Reply With Quote
Old 11-07-2013, 12:08 AM   #10
Chris82xx
Chris82xx's Avatar
I sent you a Pm.
That is insane!! I would have never thought that a motor like that could cost that much. I wonder if they offer financing options?
811RWHP/719RWTQ
Old 11-07-2013, 12:15 AM   #11
JLE58
lol! Once you get over 1800 hp it cost to get a motor that will last a whole season. Of course if you buy the motor you get Steve Petty to tune it. If i wanted a 2500 hp drag car I would be at proline. Keith Berry and Proline are running 4.19 in the 1/8 with an LS engine thats crazy...
Old 11-07-2013, 12:45 AM   #12
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
Dang J. We are in the same boat... Though I'm going to stick with ERL for my needs... Superdeck I six bolt... Time will tell, but it will do what I need...
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 11-07-2013, 12:46 AM   #13
Chris82xx
Chris82xx's Avatar
To wrap my head around that is nuts in itself. In person, I don't think I can recall seeing anything like that. Aside from an exotic car. I can imagine that if you've invested enough in a induction system, then you would want top line parts for it to hold. But a motor like that, lasts how long? What is the cost to tear it down and go over parts?
Don't show Jamie this. He'll want to buy one too. He's in that mode where he's like a kid locked in a candy store.
811RWHP/719RWTQ
Old 11-07-2013, 01:09 AM   #14
Chris82xx
Chris82xx's Avatar
What do you need to do? You did the TX mile. What's next?
811RWHP/719RWTQ
